- 21 Apr 2007
Just picked off a few prices from OCUK for the NVIDIA and AMD card range, reflecting what I think would be the cards to buy (i.e not the cheapest ones available, although for some models there was only one to choose from).
GTX960 - MSI 4GB £158.99
GTX970 - MSI 4GB £249.95
GTX980 - MSI 4GB £275.99
GTX980Ti - MSI 6GB £389.99
GTX1070 - MSI 8GB £409.99
GTX1080 - MSI 8GB £589.99
380 - Sapphire 4GB £149.99
380X - Sapphire 4GB £179.99
390 - Sapphire 8GB £239.99
390X - Sapphire 8GB £259.99
Fury - XFX 4GB £349.99
Here is the new RX480:
480 - Sapphire 8GB £219.95
Ok so it performs better than the GTX970 in many games I believe, but not in others, and it is cheaper. If the AIB cards are cheaper than the GTX970 then ok, that sits almost in the right place against the GTX970, a little high maybe.
On the AMD side it is 390 performance is that what I'm reading? 390 and GTX970 being around equivalent? So against the 390 price the new card seems not to offer any real difference? And it is significantly more expensive than the card it is replacing, the 380/380X.
But if you were spending around £250 on an AIB card, then looking at those prices you would surely be silly not to spend the extra £25 on the GTX980?
Which existing card, or price point, should this new card be being compared to?
That's exactly why I've been debating a 980. Can also oc it.
