Radeon RX 480 "Polaris" Launched at $199
Just picked off a few prices from OCUK for the NVIDIA and AMD card range, reflecting what I think would be the cards to buy (i.e not the cheapest ones available, although for some models there was only one to choose from).
GTX960 - MSI 4GB £158.99
GTX970 - MSI 4GB £249.95
GTX980 - MSI 4GB £275.99
GTX980Ti - MSI 6GB £389.99
GTX1070 - MSI 8GB £409.99
GTX1080 - MSI 8GB £589.99
380 - Sapphire 4GB £149.99
380X - Sapphire 4GB £179.99
390 - Sapphire 8GB £239.99
390X - Sapphire 8GB £259.99
Fury - XFX 4GB £349.99
Here is the new RX480:
480 - Sapphire 8GB £219.95
Ok so it performs better than the GTX970 in many games I believe, but not in others, and it is cheaper. If the AIB cards are cheaper than the GTX970 then ok, that sits almost in the right place against the GTX970, a little high maybe.
On the AMD side it is 390 performance is that what I'm reading? 390 and GTX970 being around equivalent? So against the 390 price the new card seems not to offer any real difference? And it is significantly more expensive than the card it is replacing, the 380/380X.
But if you were spending around £250 on an AIB card, then looking at those prices you would surely be silly not to spend the extra £25 on the GTX980?
Which existing card, or price point, should this new card be being compared to?
That's exactly why I've been debating a 980. Can also oc it.
I'd forgotten all about that - bit of a fail IMO after the talk from some parties. Not really surprising though IIRC nVidia can massively parallelise certain aspects of geometry setup overcoming limitations in the design by brute force while AMD has a more serialised but dedicated hardware unit for it - the optimisations with Polaris were supposed to massively increase the performance there but looks like the knock on effect on overall performance is less than stellar.
Still a 20% to 30% boost it appears,whereas Hawaii and Fiji are almost the same.
Or compare the 4GB model to the 4GB 980 and 3.5GB 970. At which point it spanks then in perf/dollar. Faster card for £190 vs £250 for the 970, or £276 for the 980 which narrowly beats it. Even in AIB form I expect it to be rather cheaper than a 970 at 4GB if you feel AIB cards are necessary, though with such a lower TDP the cooler as-is isn't such a limitation, which is the normal reason for going AIB in the first place.
The 970 GeForce GTX 970 OC "Reference Fan" would be a closer comparison.
£210.
I would consider it a fail to buy a card almost 2 years after it's release for almost the same money.
Does the RX 480 give enough improvement over an almost 2 year old card. Obviously Brexit is hurting AMDs thunder, if the £-$ was 1.5 this would be a decent card upgrade at a good price, but now wouldn't a lot of people regret not having brought a GTX 970 20+ months ago and had that 20 months of gaming for the cost of £50 in lost new value?
For people just entering the PC gaming market or those that can only recently afford a card in this price range it's a better deal as they won't have such regrets.
Yeah.
I was always going to wait for the AIB cards for my purchase. I hope they do eek out a little more performance with the better cooling, more power connectors and manage to keep a decent gap to GTX980 price. £230 is the golden number for me, for an 8GB factory OC'd RX480.
I think as its new gen, 8GB should be expected, so its a fair comparison to compare old 4Gb to new 8Gb, from a consumer/new tech point of view.
Yeah.
Cool, so if you're buying now you'd say "No I won't have newer faster tech for less money as it's new tech so should have been a bigger jump, I'll buy the old one" .... ?
Why is there a bandwidth difference between the 4gb and 8gb versions.
That... is a bit annoying :(
£210.
The RX480 4GB was around £175 today,so not sure how £35 cheaper after a 21% stronger pound in 2014,is that bad.
So,£35 cheaper than the GTX970,but as you know the exchange rate in September 2014 was $1.62 to a pound:
http://www.exchangerates.org.uk/GBP-USD-30_09_2014-exchange-rate-history.html
ATM,it is $1.34 to a pound:
http://www.exchangerates.org.uk/Pounds-to-Dollars-currency-conversion-page.html
That is a 21% difference from when the GTX970 was launched in September 2014.
OFC,typical AMD launch timing!! :p
It could be a bit GTX 970
Simply going from 4gb to 8gb should make no difference to the bandwidth.
