Wonder why it is so hard to push these cards so high. Trying to stop myself from running out and getting one, before the AIB versions come out.
Slightly confused...Apparently the 6 pin is wired for much more than actually needed, so 8pin will potentially make no improvement.....
It's not like the new nvidia process OCes a lot, people hype about 200mhz boost on 1080s and 1070s but in reality it's barely 10% since the clocks are already high and the cards barely go further than the boost clocks on AIB cards.
I think we won't see more than 1400-1450mhz on those cards and the ones that hit more will be cherry picked chips that will come at extra cost.
Either way, at 1400mhz this is already a beast for the price.
What perf is it at 1400Mhz ? (What card is it compared to at that speed?)
Fury x by the firestrike score.
Impossible to say before it's actually tested in real games.What perf is it at 1400Mhz ? (What card is it compared to at that speed?)
Sapphire Edd said they had sorted the PCB for the Nitro, which hopefully means they sorted power delivery to actually a normal method which in turn I hope will help overclocking.
If it's 1350 and you can get a 10% OC that's going to put it at 1455, and if a 1410 oc puts the card at FuryX perf in 3DMark, will be interesting to see how it fares in gaming.
Then the Toxic is coming at a rumoured 1375, that could get close to 1500 potentially? Wonder what kinda performance that would yield?
If people are getting 1350 overclocks on the reference then wouldn't that put it close to a 390X?. Not too bad for a budget card really.
The AIB cards will be the main cards to go for anyway since nearly every gpu has always sold more non-reference versions and with 1400MHz OC you are essentially getting a Fury for a budget price.![]()
Well going by the guys stream, he managed to get a watercooled reference rx480 to 1410mhz stable on core with fury x performance from the firestrike numbers. he couldn't get it past that even with modding it with more capacitors to smooth the voltage.
he tried to volt mod it, but it appears to be a pain to do, so he didn't manage in the end.
The problem is, now that it's out it doesn't matter actually how much of an issue it may or may not be. The nay sayers, the fanboys and the press have the news and therefore it won't die.
It worries me though how this is much more of an issue to a lot of people than the whole 970 3.5GB thing.
His equipment ran out of batteries, so didn't attempt to volt mod.
Also, I may have missed this, but did he say that the 6-pin only powers the core and not the memory? That's interesting if true, because that PCper video shows that it draws from the pcie a lot more than usual at the expense of drawing less from the 6-pin. (Around 75W both at stock).
If, at stock, the core alone is drawing around 75w, if they had used gddr5x that would have made the total much better. As Raja said in the PCper interview though, they could have gone for perf/w or perf/$, on the memory they chose the latter.
