Seen this if you want to watch it...
Wot, man this thread 500,000 + views
http://www.guru3d.com/articles-pages/nvidia-geforce-gtx-1080-review,28.html
according to there;
14,300k is fury x
15,600 is titan x.
That is your own persecution complex speaking.
The 3.5GB thing was a massive story at the time.
I'd be careful of saying no problem - the cards can get close to the max safe amperage for the gauges involved and when talking about overclocked + crossfire you can be potentially talking about in excess of 100watt over nominal spec through some parts of the motherboard which will demand a lot of the relevant VRM, etc. cooling.
Most likely scenario worst case is thermal or current protection kicking in and shutting down the system but you never know.
EDIT: If I'm understanding the video linked above correctly then in the rare event of partial failure of the pci-e 6 pin source you could potentially stress test your motherboard's ability to cope with over current :s
according to there;
14,300k is fury x
15,600 is titan x.
So basically what it boils down to is: if you have a reference card don't overclock them and they stay within the design spec and its fine. If you want to overclock then get a AIB card instead.
The reference cards were clearly designed with a budget in mind for people with little to no overclocking ability on their motherboards and limited over current draw in their PSU's i.e. OEM and budget builds. They didn't take into account benchers who would push them beyond their design specs and and then post results. Theres a reason overclocking is always stated to be at the owners risk because its out of spec, if theres a fault here its that they should have been locked down so they they can't be overclocked. It looks like there will be a driver update to address that. But then people will complain because they can't overclock them instead!
Could be a great source of irony if AMD are releasing overclocking tools when their latest card is incapable of taking an overclock.
Those evil engineers designing things to spec and not overspec.
I'm a bit perplexed by the configuration I can't really believe it to be an oversight but it does read like they originally intended it for another platform and overlooked sorting it properly for a desktop GPU.
https://forums.overclockers.co.uk/showthread.php?t=18485414
GPU score is what counts and it was 14900 which is gtx980/390x perf. His overall score is inflated by the i7-6950X with OC.
+1 Think someone was getting a bit excited and forgot to look at the details.
At 1400mhz the rx480 with a Gscore of 14600-14900 is around 1.1ghz 390x to throttling stock Nano in firestrike GRAPHICS score.
The fury 3584 stock to clocked ranges from 15000 to 16500 gscore
The Fury X stock to clocked ranges from 15500-17500
Average rx 480 clocks seem to be 1330-1350 on ref cards so far.
Gm200 980ti/ titan x g scores are anywhere around stock 17k to oc'd 21k
Firestrike?
13,906 on a GTX 970 @ 1554/1950
http://www.3dmark.com/fs/8573432
Actually not bad, not bad at all.
Its not bad tho...
1,100 GPU points above my 1550Mhz 970, if those Board Partners could find another 100Mhz they would start to look pretty good at £250.
agreed if they can reliably get 1400-1450 with the aib the 480 is a beaut. Just a shame they couldn't make a 2560 shader jobby with 1350-1400 guaranteed.
I think the only reason 970/390 owners are so fixated with the 480 is because they don't have any other options at their price range - but then what did you expect, higher end cards at launch will always be more expensive, so if you want more performance there's always the 1070 & 1080. There will be no world where you'll have cheaper options for that kind of performance.
