I provided a link that showed the FuryX pulling 300w, higher than the 275w figure that AMD states. The same link showed the 290x pulling 286w, well over AMD's 250 published figure.
http://www.guru3d.com/articles-pages/amd-radeon-r9-fury-x-review,10.html
To take it back to what we are actually talking about here.
The 290X has 300 watts of power inlet
The Fury-X has 375 Watts of inlet
As to the question of whether or not AMD tend to use more power than their TDP rating 'your words', they don't, we don't really know what AMD TDP rate their GPU's at, they don't tend to publish that info, its pretty usless as i explained.
So, your original argument, to put it more accurately, was that AMD use more power than they say they do, right?
And there in you argued that the Polaris 10 TDP <
forget about that, lets just use the real measure, power consumption, would be more than 150 Watts as AMD also underrate TDP / Power consumption, call it what you will... right?
Well, i reiterate the Fury-X has power inlets of 375 Watts and uses less than 300 according to your own links.
290 power inlets 300 Watts and again uses less...
Now, Polaris 10, power inlets 150 watts, so the evidence, your evidence suggests an actual power consumption less than that. not as you argued (while not understanding the difference between TDP and power consumption, which also being completely irrelevant to your argument < proof you never understood it at all) more.
Right?
Fury-X power 375 Watt, uses less
290X power 300 Watts, uses less
Polaris 10 power 150 Watts, uses less.
All soooooo simple.
