Red Dead Redemption 2
Today's patch has totally broken the immersion of my game.
Will have a look at drivers n stuff tomorrow but the same settings as yesterday now giving 45 in camp and mid 50's in other places...
Seems to run a lot better after the patch, everything on Ultra now with better performance, it ran pretty well for me on day one so this is just a bonus now.
Hopefully they'll improve performance further. :D
So this is everything on Low....
and this is my GFX card utilisation.
ugghhhh :mad::mad::mad::mad::mad::mad:
I'm waiting for a Blondie, Angel Eyes and a Tuco mod :D
Already a few character mods :D
I'm surpised the physics and animations just seem to (mostly) still work when swapping things around like that. Usually when you try to do that in games in breaks everything.
Which drivers were you running @Strudders, latest ones and had to reinstall on top of those?
I was on 441.12 the game ready drivers and reinstalled with latest 441.20
I was really jumping the gun TBH. If I had thought about it instead of getting hacked off, I usually have to do it for GTA every now and again.
Anyway did a major chapter three mission and was solid 60FPS
It seems my game runs better now, I turned most stuff up to high today and it ran nice/ gtx 1080 1440p.
I still have bug where mouse curser keeps coming back and getting stuck on screen. Im playing on pad and every 1 min or so I have to move mouse off screen. It's kind of annoying. any one know how to fix?
Didnt see anyone posting the patch notes, so here they are, quite a few fixes in here
Red Dead Redemption 2 November 13th PC Update Release Notes
Graphics & Performance Fixes
  • Added an additional launch argument (-cpuLoadRebalancing) to rebalance workload on the CPU cores and avoid hitting an edge-case in certain NVIDIA graphics card drivers that causes significant stalls on 4-core and 6-core CPUs
  • Added improvements for performance and stability on graphics cards with 4GB of VRAM or less when using Vulkan
  • Fixed an issue that resulted in audio stuttering and sound drops on some CPUs when using Vulkan
  • Fixed an issue that resulted in graphics problems when using Fullscreen mode on systems with multiple displays
  • Fixed an issue that resulted in the game becoming stuck in Windowed Borderless mode instead of Fullscreen mode if the game lost focus or certain graphics settings were changed under DirectX 12
  • Fixed issues that resulted in the incorrect detection of devices and problems switching between SDR and HDR modes. Players who previously encountered these issues should enable HDR through the Windows Display Settings prior to launching the game
  • Fixed an issue that resulted in the game launching in a window larger than the maximum resolution of the attached display when using Windowed display mode
  • Improved the auto-detection of system hardware so that the recommended default graphics settings will provide higher performance
  • Fixed an issue that resulted in the game setting a default graphics preset that was unsupported by the amount of available VRAM on some graphics cards, preventing the game from launching
  • Fixed an issue that resulted in VRAM usage estimation for pending settings changes to be slightly different to the actual usage once the settings were applied
  • Added a separate option to enable tessellation on tree models within the Graphics settings menu
  • Fixed an issue that resulted in reduced performance when switching between different graphics settings presets without restarting the system
  • Fixed an issue that affected the brightness of Photo Mode images that were captured in HDR after editing them using the Social Club menu
  • Fixed issues with some full-screen effects and Photo Mode filters when using a display aspect ratio other than 16:9
  • Fixed an issue that resulted in graphics artifacts in mirror reflections when using Multisample Anti-Aliasing (MSAA)
  • Fixed an issue that resulted in graphics artifacts on the Pause Menu Map when using Multisample Anti-Aliasing (MSAA )
  • Fixed issues with rendering and lighting that occurred with some waterfalls
  • Fixed issues with rendering that occurred with a Story Mode character
  • Fixed an issue that resulted in flickering graphics artifacts on some systems using multiple graphics cards
  • Fixed an issue that resulted in graphical corruption during the theater shows in Saint Denis
  • Fixed an issue that resulted in graphics artifacts to appear when rendering some light reflections
  • Fixed an issue that affected the rendering of the Pause Menu background after changing the display resolution
  • Fixed an issue that resulted in reduced world detail at long distance when using items that allow zooming, such as scopes and binoculars
  • Fixed an issue that resulted in rendering issues with shadows on some parts of the terrain
  • Fixed an issue that resulted in graphics artifacts that could occur with some hair/fur rendering when using Multisample Anti-Aliasing (MSAA)
  • Improved the performance rendering some in-game particle effects
  • Improved the performance rendering of trails when in snowy areas of the game
  • Fixed an issue that resulted in the partial rendering of the Pause Menu while some graphics settings were active
Stability Fixes
  • Fixed issues that resulted in crashes during game startup and logo screen
  • Fixed issues that resulted in crashes when changing graphics settings or switching back and forth between presets
  • Fixed an issue that resulted in crashes during the initial boot of the game in the Windowed display mode
  • Fixed an issue that resulted in a crash when switching between Windowed and Fullscreen display modes on some graphics cards
  • Fixed an issue that resulted in a crash when the game window lost focus or as a result of using Alt+Tab
  • Fixed an issue that resulted in a crash when attempting to load an autosave on some systems
  • Fixed an issue that resulted in a crash when repeatedly transitioning between Story Mode and Red Dead Online
  • Fixed issues that resulted in crashes when attempting to quit the game
  • Fixed an issue that resulted in a crash on some systems when connecting and disconnecting input devices with the game running
  • Fixed an issue that resulted in a crash when attempting to switch weapons in Story Mode
  • Fixed an issue that resulted in a crash when opening the HDR Calibration screen with some combinations of graphics cards and displays
  • Fixed an issue that resulted in a crash when using the mouse to switch between categories in the Satchel menu
  • Fixed an issue that resulted in the game freezing when applying remapped keyboard inputs through the Settings menu
  • Fixed an issue that resulted in an infinite loading screen when exiting the Settings menu and returning to the Landing Page
  • Fixed an issue that resulted in a crash when playing Story Mode while offline
  • Fixed crashes and stability issues that resulted in the error “Red Dead Redemption 2 exited unexpectedly” during gameplay
  • Fixed an issue with attempting to join another player’s Red Dead Online session with a different control scheme or lock-on type that resulted in networking issues
  • Fixed an issue that prevented the Red Dead Redemption 2 desktop shortcut from correctly launching the game
Control & User Interface Fixes
  • Improved mouse support in some Store menus
  • Fixed an issue that resulted in a black screen during the initial boot of the game rather than the loading bar
  • Fixed an issue that resulted in players being unable to equip emotes in Red Dead Online while using the mouse
  • Fixed an issue that resulted in the Map in the Pause Menu being cut off when changing the game resolution
  • Fixed an issue that resulted in player overhead displays to appear in the incorrect position on displays other than 16:9 aspect ratio in Red Dead Online
  • Fixed an issue that prevented some keyboard inputs from being remapped
  • Fixed an issue that resulted in some incorrect text and warning screens to appear when when remapping keyboard inputs
  • Fixed issues that resulted in problems with scrolling in parts of the user interface
  • Fixed an issue that resulted in some menus not displaying input controls, including Safe Zone and Brightness Calibration screens
  • Fixed issues with keyboard text input when using some languages
  • Fixed issues that resulted in the red selection highlight disappearing while browsing through menus
  • Fixed issues that resulted in problems with mouse selection, or erratic cursor movement when browsing some menus
  • Fixed an issue with keyboard navigation of the Pause Map after selecting a blip/icon.
  • Fixed an issue that resulted in players being unable to complete some actions while inspecting weapons
  • Fixed an issue that resulted in save game information to be missing from the Load Game menu
  • Fixed issues with text input of non-Latin characters and added support for more input methods
  • Fixed an issue that resulted in the Pause Map moving position after placing a waypoint
  • Fixed an issue that resulted in difficulty aiming with a mouse, especially at low DPI settings
  • Fixed issues that resulted in incorrectly sized, overlapping or misaligned user interface elements under different display resolutions
  • Fixed an issue that resulted in the loss of previous selections when navigating back and forth between menus
  • Fixed an issue that resulted in redundant options in the Keyboard and Mouse submenu of the Controls menu
General / Miscellaneous
  • Improved the stability and result consistency of the in-game Benchmark Tool
  • Fixed an issue that resulted in players appearing underneath the world when in the lobby screen while playing some Red Dead Online content
  • Fixed an issue that resulted in incorrect performance of the ‘Tap and Hold Speed Control’ accessibility feature while using keyboard and mouse controls in First Person camera mode
  • Fixed an issue that resulted in camera stuttering when using the mouse to look around while sprinting
  • Fixed an issue that caused problems with the fishing minigame when running at high framerates
I've set most things to Max on my lowly gtx 1080. One thing I can't quite fathom, is the hair on people looks strange, I can't quite put my finger on why though. I'm using vulcan, has anyone who was using dx12 and crashing tried it since the update?
Just applied the patch, no freezes or stuttering for me, if anything its running smoother than before. So much so that I might be able to turn up some extra options now. Received the free poncho but I started with a free duster and it looks rather cool so will keep wearing that for now.
Finished up the story, really enjoyed it gotta be fair :) It took me 51 hours. Now playing Online, enjoying that to can see me sinking some hours into it.
