I’ve just got this and having a play around with the settings. I can’t seem to move the quality preset slider from balanced. Is that right?
Edit is frame rate locked to 60fps too?
Have you unlocked advanced graphics settings? I think once you make changes to those it goes to custom.
Also frame rate is not locked if you turn off Vsync.
What GPU are you running?
Has anyone noticed any difference when changing the Water Physics Quality slider, I have tried it at lowest and highest and can't see any difference at all, either with the water flow or effects when you walk through it
Very smooth mate, I just turned off overlay and enjoyed the game. Benchmark on my settings I get avg 57fps this is with much higher settings than say digital Foundry recommended.
Really enjoying it.
@TonyTurbo78hey shankly fancy posting up those settings? I’m going to try to use them with Titan x pascal
@TonyTurbo78
Hi sure here you go, They was a new setting added after I taken these called tree tesselation I have that off its a killer for performance.
@TonyTurbo78
