Caporegime
If you had the money you could do that and then DSR the 3930K.
That's not really good enough
No, but manuals can and do go through revisions to add new processors as they are supported. If the OP bought the board believing that the CPU would work (either by being told it in the store
, it being advertised,
or being in the manual that shipped with the board)
Anything else is just plain "goods not fit for purpose".
In such cases you could contact RMA dept. of GIGABYTE UK and we would arrange for a collection and there would be no cost involved with bios upgrade
I can't see how the guy can be expected to diagnose and then flash a bios on a motherboard that doesn't even post with CPU it was designed for, in home conditions.
But I would expect you to check it, as I have in the past on every build Ive done, this isnt an isolated incident with that particular manufacturer, its happens all the time. Building your own computer means you have the inferred knowledge to do that, but also the ability to research compatibilty yourself - with the advent of the internet you really dont have an excuse.edit - on the topic of the BIOS itself, the CPU compatibility is clearly listed as 'since BIOS F8' on the Gigabyte website and it shows the release date for that BIOS to be January 2012. Personally, that would set alarm bells ringing for me, as I wouldn't expect boards with the BIOS to already be in circulating stock, especially on such high end low volume kit. (and before anyone comments, yes I would really check this and did so for my last purchase)
[TW]Fox;21431897 said:The manual is read after the purchase takes place. It is not part of the pre-purchase research or advertising. It's also unlikely the manual says 'Supports I7 3820' either.
I don't think any of these actually applied in this case, though. He decided which board and CPU he'd use and then purchased them. I imagine he had already made the choice which board and CPU he would buy before he even chose his retailer.
Except no, it's not.
Legally the store has done nothing wrong. Computer components are an expert product remember, therefore when you are buying a collection of bits you really need to make sure you know what you are doing and this involves being familiar with what a BIOS is and the very real possibility that if you are buying a new-out CPU you might need a BIOS update before it'll work.
If this sort of stuff is something thats above you - which is fine - then numerous firms supply prebuilt computers or will assemble your machine for you.
Well if something is printed in the manual that is supplied with the product that is simply not true, how is this the fault of the customer?
And i've bought motherboards that have come with a CPU support list, although it's normally a piece of inserted paper that comes dependant on board revision and BIOS. Surely this would be expected to be accurate?
I don't expect a motherboard to come with the latest BIOS, but I do expect any information supplied with it to be accurate. I was simply pointing out that the guy in question should check this, as if it's been mis-advertised then he has a case.
This is why you should shop with us.
We try our best to provide the best service we possibly can. Any reason why you never went with us in the first place?
Seems more issues and hassle than it is worth!
[TW]Fox;21432393 said:Where does he say it is printed in the manual that it works with the new i7 without a BIOS update?
I would imagine this list didn't have the I7 3820 on it.
A manual is not 'advertising' and you dont see it until after purchase but anyway, who says it was even in the manual?
I dont understand why you have suddenly decided the manual says it works with the CPU has without a BIOS flash.
The box will show the motherboard hardware revision; the manufacturer website will show that hardware revision and from that the earliest BIOS revision that it supported. Best youll glean without opening the box, but all possible before a purchase...I think this raises a couple of points.
Firstly, if buying components to build your own PC, how can you possibly be sure this doesn't happen? Especially if the boards themselves externally have no BIOS revision markings?
Knowing what revision should work isn't helpful in that case.
You are joking right? You are basically asking for an embedded processor to be installed just to cover this, its duly possible but not that sensible IMO...Secondly, surely these days it should be possible to design a board that is in some way capable of having the BIOS updated without a CPU installed?
Does that extend to free BIOS upgrades when customers return equipment to you as faulty that isn't faulty?![]()
Always had a different experience with OCUK, I remember getting a call from 5UB telling me that something was out of stock. Felt quite strange![]()
I haven't said that at all. As I explained before, I am simply suggesting ways that the customer can complain about or avoid paying the restocking fee. Only the customer himself can decide if what i'm saying is right, by explaining what he was told at purchase (if at all) or what it says in the manual in the box.
Love a link if you have one, trying to work out how you would access the EEPROM - Im sure its probably far more simple than my knee-jerk reaction; just seems overkill when most of the time research would cover you...I think some boards can be flashed without a CPU, i'm sure i've heard of it but it's certainly not a universal thing.
