Thanks for the pictures!
Should be getting monitor tomorrow.
mrk said:It comes with 1 VGA lead so you will be fine but you will ened to buy a seperate DVI cable!
I have done some tests with DVI and VGA with plain white/black test images and found that on the black image the DVI sample is ever so slightly cleaner - anyone else wnating to test this too ?
I connected both cables to my 7800gs and simply flicked the osd between VGA/DVI to visually inspect the differences. Both are just as sharp as each other and both dislpay the same colour clarity though.
KlaSh said:Thanks for awnsering me mrk.
http://www.overclockers.co.uk/acatalog/Video_Cables.html out of the cables in there, which one do you recogn would i need to buy?![]()
Just getting all my questions asked(awnserd) before i buy the monitor etc
bit of a nub at times me![]()
markyb said:Thanks for the review mrk.
It does look very nice.
Three things are putting me off buying this at the moment, Let me explain.
- First off, Why is it so cheap?
I spent £279 on my Samsung 913n when it first come out, ok that was a year ago, but there are other models with around the same specs but much more money - £200~
What do the dearer monitors have on this model?
- Secondly what happens to the Games which dont allow me to change to a
Widescreen Res?
Do they stretch, and if so do they look ok like that?
- Will there be any benefit in changing my current Samsung 913n for this?
Apart from it being widescreen, better quality?
If Gibbo says its the best he has seen recently, then thats good enough for me!!
