Caporegime
I thought they were wall mountable
The spec on OcUK says 'Kensington ready (Wall Mountable)'.
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
(t31os) You need to add the resolution commands to the command line for the bf2 shortcut
I think you can just undo the screw on the hinge and the screen will detach.(pigeon_killer) I thought they were wall mountable The spec on OcUK says 'Kensington ready (Wall Mountable)'.
http://www.fixit-4u.net/mrk/root/temp/wp_CRW_4462.jpgBaddass said:the 3 scenery ones if possible![]()
NeilFawcett said:Two comments on this monitor...
1) I tried it with a standard VGA connector and DVI connector, and could see no difference in the image quality.
2) The INPUT selection button allows selection of the three inputs (DVI, VGA1, VGA2) as follows. You hold the INPUT button down for 2-3 seconds, and then a menu is offered. You can then cursor through the three input and press MENU to select. Could be a touch slicker, but better than having to rummage around in a full menu system.
dobbs2010 said:I take it you finally took the plunge and bought one Neil. What's the scaling like at other widescreen resolutions, such as 1024x640 and 1280x800.
NeilFawcett said:By scaling, you mean how blurred or non-blurred it is?
Well so far I've only run FEAR at non-native resolution, and that appeared fine.
Give me an example of something you want trying and I'll see what I can do...
