- 31 Aug 2017
Lol its not going to be the card, sounds like a cop out for crap software.
Don't you think it working before the firmware update points to an issue with the firmware rather than the card?
Or maybe saying an issue with one or the other isn't quite right - an incompatibility between the two.
Thank you for contacting Nvidia Customer Care. My name is Josh and I will be assisting with your case. We do not have any known issues with using the Rift S and the 1080ti. In our testing it is working just fine. We do not have a Pallet card. This could only matter if the ports they used for the card have issues or are not the same as other cards. It is also possible there is a software conflict. I think what you will need to do here is some more troubleshooting.
If possible to eliminate software conflict. Do a fresh windows install latest updates and just the basics for VR.
To see if the issue follows the card, if possible install the pallet 1080ti in another system and try the rift S. If it happens here then it has to be specific to the card.
You could also contact Pallet directly and see if they know about any possible issues with the ports they have installed on the card.
nVidia's second line support got back to me today. But the only suggestion they had which I haven't already tried is installing the card in another computer. I don't have another myself, and I don't think I can do that with a friend. Too much of an imposition. Their suggestion seems to be Palit might have used a differnet spec of displayport than other manufacturers. I know Sideways said he has the same card - but was it the exact same card? Palit have at least 3 models of 1080Ti.
Here's their full reply:
So back to a plan of buying a 2070 Super. Selling this card at a slightly knocked down price to someone who definitely doesn't want to use it with a Rift S (it's been absolutely faultless apart from this!)
With all the troubleshooting you have been doing and how long it's been dragged out, it's now only a month to black Friday, might be worth waiting for some deals!!I'm not expecting any further progress to be honest. It's not a faulty card, except possibly by an incredibly narrow definition, so even if it were still under warranty I don't think they'd be doing anything.
I've still not got around to playing anything on it though, because now I've got to build my chair!![]()
Well, the 2070S is installed.
Oculus nearly gave me palpitations by going through the same process of working, then requiring a firmware update...
But this time it continued working after said update. Phew!
And that you survived the heart palpitations
Can you try one more thing with your card. It's a totally safe procedure. Some Nvidia cards have display port problems, especially Pascal and Maxwell cards and they released a tool that checks to see if your card needs a firmware upgrade. If it needs an upgrade it does it.
You can download it here.
https://www.nvidia.com/content/Driv...ter_1.0-x64.exe&firmware=1&lang=us&type=Other
i have been struggling with black screen issue and looking for a solution on internet for three days. I have a gtx 1070 gpu and when i wear the headset i had the displayport problem. Yesterdey i have updated the firmware of gpu as you suggested at the link above. And it worked! I have tried all other options before and started to think about changing my graphics card. Luckly the problem is solved by your suggestion.
Thank you melmac![]()
Delighted that it helped someone!!
