Battery B is taking shape, just need to connect up the balance cables tomorrow and it should be alive.
![Battery-B.jpg](https://i.postimg.cc/sx6ZwN0B/Battery-B.jpg)
Hopefully just a glitch, it's the BMS access problem that's annoying.
No rodent protection, perhaps I should shut the cat in there. Apart from putting out some poison, which will also attract rodents there's not a lot I can do.
Yes, default for pairing is 1234I had to side load the new app - the one on Playstore is well out of date, I didn't try rebooting though. May try a different phone, just in case. The default pairing password is 1234 isn't it?
Apparently it is possible too get a temporary password, which works for 30 minutes, unless this is a pre-existing password no idea how they set it up as the BMS is not internet connected.
Doh! You are correct, no idea why I thought the one I downloaded was newer, just uninstalled and installed the Play Store version. Not that it will make any difference, as I did originally have that.Think the app you have installed is to old, Playstore one looks to be 18 revisions ahead of the one you have installed
PS That old app works with the new BMS.
I've actually been doing some more work on the battery system, need to get my battery heating sorted out.
I jerry rigged the system up over the weekend, just to get one working, to see how it worked and how it needed to go together.
You can see battery A warmed up a little around midday, so it does work.
I also need to get some polycarbonate sheets, to make a cover for the batteries, this will also help keep some heat in as well.
what is the total cost of this? havent seem you mention yet
