- 5 Jun 2013
have you got your export setup yet?
Yes, been setup since April, BUT my Octopus usage doesn't show anything after 23:30 on Friday for electric, import and export. Funny how the Bright app shows the import though, clearly an Octopus issue.have you got your export setup yet?
how much are you exporting today?Yes, been setup since April, BUT my Octopus usage doesn't show anything after 23:30 on Friday for electric, import and export. Funny how the Bright app shows the import though, clearly an Octopus issue.
Prob my setup in the Van, battery is well wrapped up, the terminals are covered under a blanket.They are not bolted to the terminals, they are fitted to the side of the cells, located between the bar which holds the pack together and the cells, the only source of heat there is the cells themselves.
They both measure a few degrees lower than the BMS temperature sensors, so should be plenty of safety margin.
I also calibrated the sensors - beaker full of water and ice cubes, left it to stabilise then set to zero.
The battery heating system works, as I'm not currently force discharging the batteries don't get their late afternoon warm up, so they are dropping to 8°c and the heaters turn on and warm them up to 12°c
The first big hump is when the charging kicks in at 2am, then it starts dropping at 5am, where the green and orange lines start rising again is the heating system warming the batteries up. Temperature outside at the moment is 0°c, and the garage is 3°c
I don't think you'll damage them. What I've found is if they are charged quickly when cold they just accept less by the time they get to 100% SOC. This morning at the slower charge rate they took 7.2kWh for a 61% increase in SOC. At that rate 100% would be 11.8kWh, so exactly what the 'usable' amount is out of the 12.25kW capacity. The other day they belted through at 5kW the whole time at about 16C and only took 9.6kWh for a 90% increase in SOC. I've seen the reverse in summer at about 30C battery temp; I can get slightly more than the stated capacity out of them.@reef I'm in total control, so its whatever I want, hopefully I'm not damaging them! I charge them between 2am and 5am at 130A, as there are two batteries that's split in half, so each battery is receiving about 65A, or 0.23C which is battery speak for the charge current related to the Ah capacity of the battery. The manufacture of the cells states "The maximum charge current of the battery does not exceed 1C under 0℃~45℃", I think under should mean between. So I should be perfectly safe charging the cell's as I am. Below freezing they should not be charged, or only with very low currents.
EVE LF280K 3.2V 280Ah LiFePO4 Prismatic Battery Cell
Factory sale grade A prismatic cells lifepo4 3.2v 280ah battery for energy storage and power lifepo4 batterywww.evlithium.com
Last night the temperature in the garage got down to 2°c.
PS. There's some interesting info at https://community.victronenergy.com...w-charging-lifepo4-when-freezing-weather.html
My batteries currently down to 12%, so I thought I'd look at home assistant and see how much I'd discharged today, it shows 23.12kWh. This is a calculated figure.
Now if we divide that by 88, then times it by 100, it gives me 26.27kWh, which is not that far off my maximum battery capacity of 29 kWh. Considering I don't use the full cell voltage range, that's pretty good.
Edit. Actually, that's not quite right, there was some discharged between midnight and 2am, then the battery was only charged to 87% by 5am, so usable capacity is greater than above.
Just an FYI there's isn't a Solar Systems Anonymous yet, to deal with your addiction.Getting very close on my plan for my third solar install![]()
