- 5 Jul 2005
I'm hoping ocuk may do a £229 early bird special.
If Nvidia provide a discount to retailers, which won't happen, you might see £250. More likely initial stock at 299. Then quickly over £400 quid. Great budget option.
100% more than the AMD card, but its great budget option? It`ll also be more expensive than the 3060Ti FE card.... go go Nv!
Apparently the reviews are coming out on the 26th. And then release the next day. So at least you don’t have to scramble to buy something that you won’t be happy with.
This is how it should be done!
yeah that way you get to see the reviews and then you can make a decision not have to order it before it go`s out of stock and then find out it`s crap and have to send it back. AMD fiddle
RTX3050 scores 1660ti performance in benchmarks
https://videocardz.com/newz/nvidia-...s-gtx-1660ti-performance-with-dlss-raytracing
I'd pay £250 max if the reviews confirm it performs like a 1660 ti. Ideally around £220 though.
The 3050 trashes the 6500xt
1660ti performance is less than what most people were expecting, right?
I dont think performance has been announced yet? But my guess is that it'll probably be between a 1070 and 1080 performance in old money.
