Caporegime
- 30 Jul 2013
Far more people are reporting better performance.
Indeed, most people are posting that their boost clocks are much more stable now and hitting higher clocks.
I just meant that all the boards that changed got changed to more of the expensive CAPS so the build cost for every board built will increase. Multiply that over a million boards and it becomes a lot.
It does seem strange that almost every manufacturer increase the amount of the "better" CAPS from their pre production boards though. I mean they arent going to respond to youtubers videos to change them if there really wasnt an issue.
All retail ROG Strix and TUF Gaming GeForce RTX 3080 and 3090 graphics cards use only MLCC capacitors for decoupling close to the GPU.
During development, we discovered the improvement this makes to RTX 3090 and 3080 overclocking headroom, so we made specification changes before we started shipping cards to reviewers and customers.
Please note that some of the product images used on etail sites and our product pages were from early development samples, so are not final.
All images will be updated soon.
Please bear with us!
Well, after further experimentation, I do get a little lift in clock boost in some games. I also thing it is slightly undervolting compared to the release driver.
I can also apply a small overclock that I couldn't before, and was running Warzone quite happily at 2040 with the oc. TBH its not a lot more, it was running 2010 stock on these drivers, around 1995 on the previous ones.
So far they seem to be a keeper.
So we have a simple driver update that not only solves the issue, it also makes the cards even faster.
That'll annoy the pitchfork crowd.
With Nvidia's latest drivers, RTX 3080 and RTX 3090 users should not experience the same stability issues as before. If power-related issues persist, "GIGABYTE will provide product replacement, free of charge."
Looks like this new driver is going to gimp boosts clock to those who have good chips and no crashing like myself mine will boost to 2130mhz in places and is perfectly fine..
If you read the quoted posts, people are getting better results because it's more consistent.
RBG caps on 4080, quote me.
That’s exactly what the guy said on a video posted on the other thread. He fixed it by locking the voltage to 1v, so the GPU didn’t need more power than it could be given. Now the power limit has been upped, no voltage locking is needed, the power will be ample to drive it at its max boost.As I understand it the drivers are upping the power the cards take to push the point the capacitors struggle beyond other limits.
