DF and Gamers Nexus have shown that you are wrong, especially this myth that things equal out at 1440p. They both use 3200, GN even used 3466 which most Ryzen owners won't reach and Ryzen was still well beaten. Even at 1440p on the GN review. In many cases it's easily 20%+.
Gamers Nexus used 2 games ONLY at 2560x1440 and both have explicitly have shown issues with the Ryzen CPU.
Especially TWW1 runs constantly on the last thread not core of the given CPU, consuming it at all times at 100%, and barely any other thread or core is being used. Hence why Intel systems at high clock speed perform better.
Anyone who has the game and puts the MSI AB overlay will say the same.
Also it has issues with NV DX12 that cripples it's performance even on the 6800K, because of the above issue. At DX11 is less prominent and the FPS 30% higher.
While others using TWW2 on the benchmarks (along side numerous other current games), shows completely different picture, because TWW2 is running on CORES not THREADS, which the tweaked engine avoids like a leper.
It also scales greatly among multiple cores, depending how many resources are available on the last core which is running again at 100%. That levels out the performance even at 1080p.
There are videos showing 76% usage on core 4 for a 5Ghz 7700K and the rest of the cores moving accordingly. While on lower speed CPUs, the last core runs at 100% and the other cores see heavier loads. But the fps are always dependant of the GPU and same across the board.
For example another review, more games tested
GN also, knew exactly which games they will pick, as per Intel's instructions. (yes they exist hence many reviewers said that they don't follow Intel's advice on how to do the tests)
There was no Tomb Raider for example, a game very common the last year on benchmarks, why?
Also European sites, getting their CPUs from 3rd parties to test, not ES modules directly from Intel, show a completely different picture.
On top. Do not trust the current 8700K benchmarks. We have no idea what sort of golden chips were on the first batch and on reviewers systems.
Why I say that?
Intel covering up their bottoms, only promise now 1 core to hit 4.7Ghz. The rest even if they can work at 4Ghz or less, doesn't matter. Is not their problem, because legally they cheat nobody....
http://www.guru3d.com/news-story/in...close-multi-core-turbo-boost-frequencies.html
And knowing Inte's shadow tactics over the years, I foresee some funny threads popping that performance isn't what expected, and cores are running at low speeds.....
