1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Ryzen build - £1700
Discussion in 'New to PC gaming & upgrade advice' started by subbytna, Jul 1, 2017.
  1. Plec
    Sgarrista
    Yes, or you could try the Customer Services Forum as this can be quicker on occasion - especially something as simple as a missing bracket.
  2. subbytna
    Yeah sent a message. Hope they get something in the post tomorrow as client wants the PC on Friday
  3. Plec
    Sgarrista
    If you post the urgency in the CS Forum I'd be surprised if they don't deal with it immediately and post it out first thing.
  4. subbytna
  5. mickyflinn
  6. Plec
    Sgarrista
  7. subbytna
    The cooler head is square though, not round, it doens't fit into the brcket I was sent. CS sorted it though, 4th time lucky lol. I get to keep the other 3 mounting kits....if anyone wwants one lol :p
  8. Plec
    Sgarrista
    Wow - you've been unlucky :/
    As you say - hopefully 4th time's a charm...
  9. stulid
    Don
    Does the AM3 kit that came with the cooler not fit the AM4 plastic brackets on the board?
    You will see on the plastic brackets on the board there is a "tab" that sticks out.
    The AM3 kit with the cooler has those "T" looking loops that should attach to the tabs.
  10. subbytna
    No it doesn't fit. Believe me I've tried. CS sending me out a new bracket today.
  11. shaun2007182
    Gangster
    Did you get the new bracket and which one is it? as I am thinking off getting the same cooler for same cpu.
  12. subbytna
    You need a specific "square" am4 bracket...I'll post up a pic when it arrives on MOnday.
  13. subbytna
    I've discovered that one of the sticks of RAM I got won't work. The mobo wont post when it's in. The other 8gig stick works fine and the mobo posts when just that one working stick is in. I've tried in different slots and different combinations and 1 stick deffo doesn't work. What's the usual way to resolve this? Do I return 1 stick or both or how does OCUK normally operate in this situation? DO they ask for both sticks to be returned if both sticks cam in one pack?
  14. Plec
    Sgarrista
    As it's dual channel kit you're better off returning both - they'll probably require that you do for their return purposes.
    Post in the Customer Services Forum or ring tomorrow to set up an RMA - proabbaly be approx. 4-7 days turn around.
    Or if you're really sure one is borked and need the memory faster - buy a second kit and send the other back for a refund.
    EDIT: Just realised what build this is - you've not had much luck :/
  15. subbytna
    Yep, ball ache central lol....ah if I didn't laugh, I'd cry.
    Thanks for the heads up
  16. Plec
    Sgarrista
    No worries - i suspect you can't wait to get the build off your hands if it's for a client.
    Some builds are just b*st*rdy b*st*rds.
  17. subbytna
    I think I'll buy a new set of RAM and get a refund. Faster that way. The client is understanding....to a point.
  18. subbytna
    It cost me £128.20 to get this ram replaced :/ Dam this build has been the bane of me :(
  19. Plec
    Sgarrista
    Memory prices are a bitch - and no signs of going down thanks to the mobile market.
  20. subbytna
    I had it on offer for £109....Hopefully Bailey can help me in the CS section
Share This Page
