Hi there
Just been out for another drive.
Wound it up to 4500rpm this time and oh my the sound!! Its so much better than before. It now sounds like there is 7.0l under the bonnet even on normalish acceleration. Foot to the floor and it whines oh so lovely, gonna keep it all sub 4500rpm for now and keep a check on everything.
Also MPG seems hardly effected which is good. All I can say is booting it in 4th from 1200rpm just result in insane pickup, its real nice.
Can't wait to get it on the rollers and get the lowering mounts in as it is rubbing against the bonnet insulation ever so slightly.
Gonna put about 400-500 miles on it before I truly start taking it upto 6000rpm and I need to get used to it myself. Plus at the moment she is running on a very conservative and RICH tune for safety until I get some A/F readings. Supposedly once they get my A/F ratio they might be able to give me upto another 50BHP, crazy stuff.
Plus I never gapped the plugs, setting them to 0.32-0.35 can yield some extra power too as that is the recommended setting.
Also beginning to master 2nd, half throttle upto 3000rpm which still pulls harder than full throttle previously did and then nail it and my god its like the world is ending. Absolutely loving it!!!
Also handling and steering response seems un-affected considering there is another good 30kg on the front-end. However once its dropped 1/2 inch it will handle nicer.
