I played on one of these at i36 last weekend they are amazing!
I 2nd that, played burnout game at the Gadget Show Live,,, really, really want one, but could i go down from a 24" to 22" monitor, that i dont know???
Yesssssss i'll be first on the pre order list
Edit: Actually, it's probably better to wait until 120hz has matured a little. When/if I do a screen upgrade, I'll get it then and adopt the next technology. Maybe when OLED's come round or something.
Also looking foward to seeing a 120hz LCd on stock.
**edit** http://www.overclockers.co.uk/showproduct.php?prodid=BU-000-NV&groupid=17&catid=949&subcat=
A bit more pennies then I was expecting, I will wait for some more FPS Game reviews.
By buying this bundle you save £7.16 (8.23 inc vat)
a whole £8.23
think im going to treat myself to a nice meal at a fancy restaurant
Does anyone know if ATI are going to do a version for their card??
The Nvidia stereo mode is a joke, (possibly) heavy glasses that need batteries that basically cause you to wink one eye then the other. With the "3d" mode you still only get 60fps because each eye only see's half the frames but without the 120hz screen's you'd be at an incredibly painful 30fps all the time. Either way the glasses need batteries which will weigh something, and need constantly recharging or replacing, probably not be very comftable due to glasses and battery weight and the tech gives you headaches with longer use. nvidia does it again
I have spent about 30mins playing with these and can say the the glasses weigh no more than any normal pair.
Forget the glasses, what's the monitor like at 120hz? is it just as good as a CRT ?
As you can see, the lens is translucent only 2 milliseconds out of each 16.7 milliseconds. That is, most of the time both lenses of the 3D glasses are shut and the monitor has 6.3 milliseconds (because the frames go at a rate of 120Hz, i.e. one frame each 8.3 milliseconds) to change the picture.
Unfortunately, such a low on-off time ratio (with a short period of translucence and a long period of opaqueness) leads to a 60Hz flicker. The perception of the flicker depends on the particular person. Some people may take no notice of it while others will have sore eyes, but the flicker is indeed perceptible.
I would love to buy this, just, £400! Pfft, no way a 15 year old can get that...
