Caporegime
- 18 Oct 2002
Yup, I'm crying out for a bigger Navi chip but tbh by that time I'll proably have switched to a 4k/120hz screen anyhow
Heads up. This is £999 at a certain large shopping website. Going to place my order tonight. Fingers crossed for a good panel.
That's less of an issue than the Freesync/Nvidia problem, but depends what games you play. With an AMD GPU though, no problem.
My fourth panel is coming tommorow. Fingers crossed.
Sadly even if it is perfect, if I'm impressed by the LG 55'' OLED I might just go for that. I phoned Currys and their techknowhow for £6 does cover burn in.
They confirmed that? For PC use? I do wonder if it would be a loophole, given the use an OLED would get on a PC... far more than it would as a TV (its 'intended' use). I know they can check software for usage, so if burn-in occurred, it would concern me that this could be used as a reason for them to not cover burn-in, as you wouldn't be able to pretend the display hadn't been hammered.
My concern with burn-in on any OLED relating to PC usage wouldn't be gaming, but rather web browsing or work stuff (Photoshop, Premiere etc.), anything where you have fixed windows on screen for hours. I don't think gaming would be a concern, unless you were doing mammoth sessions in the same game, EVERY day of the week.
Fourth panel is perfect. FFS. I get a perfect panel now that I've ordered the 55'' C9 OLED. Will do a comparison and probably a thread next week to describe my thoughts on what I think are the two best value gaming panels on the market.
Congrats!
May I suggest you to do a video review since you're so enthusiastic about both CRG9 and C9?
Got mine set up on the arm tonight. Looks amazing. Hard to appreciate how big it will be until you actually get it. I have one stuck pixel in the top right corner. Can only see it on white background so it won't bother me. Can't see any backlight bleed just looking at it in a dark room which is good enough for me. Colours look great and the increased contrast from my IPS is noticeable.
Motion clarity has been good in the very limited testing I've done so far, so at the moment I think I'll be keeping it.
Pixel count is a struggle for my GPU in some games but it still looks alright if I drop the resolution, so I can live with that till I upgrade the rest of the PC.
Just to let anyone know, whos been following my grumbles. Called Samsung, they said "Thats not right" to the clicking noise (regardless of the Ghosting on top of that). So I will be sending the monitor back, thats the 3rd Monitor that's been faulty!!
I have just noticed, though, OC has a new stock in - so I'm buying another one, that will make it 4. That just shows how wonderful this monitor is, when you get one that works. I could not go back to a smaller monitor.
4th time lucky, I hope!
Thanks.
https://drive.google.com/drive/folders/1FODi_cPdASLu_4HaA-PuhmDzywoVJE7J?usp=sharing
The 3rd monitor is going back because of the cracking noise, I recorded it and sent it to Samsung. They said that's definitely not right. Upon putting the 4th monitor away today, I looked at the poly inside the box and saw a big hole, then looked at the box there was a corrisponding hole. Someone at the depo hammered in a bit of iron or poll, or something similar, that went through the box, through the poly and hit the screen.
DPD.. Suck.
7
Just to reiterate, is your clicking noise from the peripheries of each monitor?
I seem to have the same (again). I just took off the plastic from the screen, i hope its just that which was expanding.. but we'll see.
Which arm are you using?? I'm contemplating how to keep the CRG9 and possibly the C9 OLED. Do you have an arm in mind which can make that happen?
Great news. A dead piel in the periphery is no big deal.. i had mine in the middle of the screen on my old one.
Hey mate, clicking noises could be heard from all over the monitor, they went away after 10 minutes though, so it's surely a heat issue. But why take the risk, the other 3 monitors I got didn't have it. The first panel had a loud buzzing noise near the top right, you could hear it changing frequency, which was annoying.
I have a bad problem with Ghosting as well, which I think is down to having a Nvidia card. There's slight stuttering as well. Lol, I have the 5th panel being delivered in about 30 minutes, this is the last one I will try, after this I will admit defeat and wait for a year until we get a full G sync option that is not filled with issues.
EDIT: Ok, got the 5th panel. This panel does have the clicking noises, but not as bad as the 2nd panel. Its mainly when I first turn on it, start up an intensive game or close a game down. Its got to be a heat issue; pretty sure its the plastic expanding, but of course cannot test this. I wonder whether to return it or not. I won't get another one. I could put up with the clicking as long as its not going to get worse.
Are you keeping your panel?
