Plug the drive in... install Windows 7
... done
Every install I've done on multiple different SSDs lately - it's always auto enabled it for me.
There's a command line command you can use to check - fraid I don't rememeber it off-hand - quick google should find it for you.
Should be enabled in Win 7.
To Enable TRIM:
1.Open the Start Menu, type CMD
2.Right click the icon and Run as Administrator
3.Type fsutil behavior set disabledeletenotify 0
That's the one... the check command is this, I think:
fsutil behavior query disabledeletenotify
Thanks guys
