I don't suppose anyone else is experiencing an annoying flicker in flash videos played in the browser? For example in all youtube videos the top half of the video has flickering lines.
I suspect my device might be faulty, however other videos that are downloaded (MKVs etc) don't seem to exhibit the problem at all![]()
ok just got it, set it up started went onto this site everything is fine, so when i double tapped the screen it zoomed in but it also kept the whole page on the screen, no horizontal scrolling portrait position which was ace, and i think when i zoomed in again it did the same. but now seconds after its doing what my galaxy s2 did where as it zooms in but now i have to scroll
thing is im sure i remember my galaxy s2 zooming in with no scroll but then that decided to start using scroll after a while, is there a setting? im on the standard browser
Change to Dophin HD.
I'm struggling to imagine exactly what you mean. Try setting user agent as desktop maybe? Is it all sites or just one?
had another play with it.. i just cant see how i could use it as a mobile phone :O
You have to weigh that up, if you require something which will be used 80% of the time to make calls on, this is not the device for you. If you however spend 80% of the time doing other things, nothing comes close to this imo, it is quite simply a beast.
I should be getting commission from Samsung with the amount of demonstrations I have given of this now, I am beginning to get sick of itbut it's the same reaction everytime..'WTF is that' and then I simply have to show them. A work colleague rang me today asking where the cheapest place is to buy the Note from, he is returning his S2 after only owning it for a week. No commission for me though.
what i meant is that it just feels to "big" but i bet i could get used that.. screen is brilliant :O i probably looked like an idiot staring at it from centimeters to see pixels at CPW.. i might be getting it or something else that size after i get bored of my S2 which does fine and its a great phone.
