no they aint the 6gbs ones just normal sata i aint got nothing 6gbs
If you have a P67 board you have 2 SATA3 ports.
Just done a quick scan on my three sata harddrives and they came out fine ......HD Tune Pro suggests I replace the drive. Anyone else want to try, the drive in question worked ok in my Q660 rig.
I am slightly curious, does anyone actually know what happens to the recalled motherboards?
Should be interesting to see what Asus say tomorrow.Most of the manufacturers X spoke to don't expect Asus to recall the motherboards in question, but to replace them as and when they fail. Y wasn't sure what position the company would take, but said: "Asus is quite bullish, saying it only affects 5% of users."
Asus had no comment other than to confirm it would issue a statement tomorrow.
The long and short of it is - if you use those ports then given enough time & load they will fail. It is a question of when, not if.Specifically, the problem’s in the interface’s clocking tree, which is the interface that governs data movement. The transistors in this interface are coated with a thin layer of gate oxide, which allows it to be activated with a very low voltage – but, crucially, the transistors actually use a higher voltage than the oxide allows.
The result? Leaking currents which, when given time to build up, can cause the 3Gb/s ports to fail. Luckily, the two SATA 6Gb/s sockets are governed by independent transistors and clocking trees, so they’re not affected.
Intel could have worked around the problem by reducing the voltage to the affected transistors, but that’s just a bodge job – the recall, although inconvenient, allows Intel to introduce fully operational processors, and allows motherboard manufacturers to ensure that the SATA 3Gb/s sockets on its boards won’t suddenly fall over in a couple of years time.
w3bbo;18368378 As a side note said:potentially[/B] have problems.
Hi guys,First post
Recently bought a Titan Spinosaur system.Very happy with it and its a great system,but this news is worrying.
I understand this is early days with this issue but wonder what will happen on any recall.Will the system go back or just motherboard?? Concerned about the o/c on the sandybridge as i dont feel confident rebuilding system (if it comes to that)
