Sapphire GTO² available exclusively from OcUK and Modding instrutions inside.....
Speed said:
Well it does say instock in the Ati X800 PCI-E section .... here :rolleyes: ;)
And yes, because it is based on the R480 design it requires extra power from a 6 pin PCI-E power connector.
Question, my Hiper 480watt psu doesn't have one of these 6 pin plugs...will it work with only the extra power connectors I already have plugged into my DFI NF4 motherboard?? :eek:
Im gonna have to say to this mod working! I do what the first post says! And i restart .... ( blank ) nadda zilch! So unless someone can tell me what im doing wrong! :D
Jakass202
I aint an idiot for sure! The 6 pin power connector is connected!! Strange though i left it for a while and eventually the screen came on when xp had finished booting :S, but ive gone back to original bios!
Could be a PSU problem!
Got the emerax noisetaker 2.0 ! Without the modded bios the pc is fine!! Got it the other day also from overclockers!!!
Same problem as cheets64 above!
Well, all the mods that have been done on this card have been 100% ok! Not sure if you are doing something wrong or you have a faulty card!
Jakass202 said:
If it was a faulty card it wouldnt work full stop yes? Plus how dare they put it on the This Week Only like £10 CHEAPER O_*
But cheats64 has said he cannot get anything on his screen! It could be a faulty card?
Just got shipment confirmation, woohoo!
Me wishes he'd paid for Saturday delivery now - doh! Oh well will have to wait while Monday.
Regards,
Matt
Its gone from bad to worse, now im old pc wont detect my hdd, after putting my psu back in it and memory.
I cant try another card as i dont have a spare pci graphics card, the psu is fine, so it could either be my new amd 3800+/mobo/memory or the x800 gto2.
if i cant get it working im gonna have to go to the place where i got my cpu/mobo/memory and see if they can sort it out.
Did you have a problem before you fitted the Graphics card? But this is a new build, right? Pity you can't get hold of a Graphics card from a mate and try that.
Is your PC coming on or not? What have you tried so far?
