Not necessarily, I’ve seen trains passing through crossings that have barely started to close more than once!
Nope. Could be as little as five seconds.
We work on railways a fair bit, including several dozen level crossings. You'd be horrified at how often ******** try to jump the barriers!
In which case, the problem is inconsistency. If the trains always passed within 10 seconds or so of the barriers going down, people wouldn't get impatient and wouldn't try to beat the barriers.
Inconsistency=bad management!(As is unnecessary delays)
"Most" peoples experience "Most" of the time is that once those lights start flashing, you might as well get out your book and start reading because you will probabally be able to get through a whole chapter before you will be underway again.
Station just down the road works like this.
Station on left, train approaching from left
Train approaching station triggers barriers, Lights come on, barriers fall.
A minute or so later, train pulls slowly into station and stops.
Another couple on minutes pass, train pull's slowly out of station and through barriers, eventually after, oh, 5 minutes or so, barriers raise and road traffic can move again.
Why?? Surely this could be operated better with the barriers only coming down when the train is set to leave.
It is this sort of stupid MO that causes frustration and tempts people to take risks!
