Be carful when using the XEON name globally, as the older non-Nocona systems are Buss Speeds of 533Mhz, and FSB's of 133Mhz, and the L2 cache is typically only 512MB, and RAM bing that of PC2100 or at best PC2700.MGP said:Bear in mind the Xeons are rated at 2.8Ghz, which will be slower than your P840EE.
SetiQueue currently suggests around 2 hours 50 minutes to do a WU. That's 8 WUs every 2 hours 50.![]()
At the moment the server is still idle as it's being loaded up and configured, so this will drop off a little.
There's a big difference between the 840EE system with L2 cache allocaitons of 1MB, higher bus speeds and faster RAM. I don't have an 840EE to benchmark, so it would be nice to see what you come up with running 4 instances of classic.
To be fair, my Pentium-M is running faster < allot faster > than all of my XEON machines. All bit it, the XEON's are running 4 instances of the core. I'm
getting 8 - 10 WU's per day from the ole laptop, which isnt' bad considering it's a first generation Pentium-M. If These could run in an HT fassion, It'd be loading up with these buggers.
For those of you running 478 Motherboards OcUK have added this neat little device from Asus:
ASUS CT-479 CPU Adaptor
Which allows you to pop in a Pentium-M into a 478 socket / motherboard. Very effecient little chips for processsing numbers.
