Caporegime
- 8 Jan 2004
- Rutland
Anybody seen any fantastic Black Friday shucking bargains out there?
12TB WD Elements is on offer.
Do you use it as a nas drive? Are they suited for this purpose?Theyre 7200rpm. I've shucked two recently.
This is the drive they contain:
https://www.google.com/url?sa=t&sou...Vaw0WHYqCdNCcXC9LOztvLmkg&cshid=1606376946143
Do they need pin mod?
I'll just leave this here as it might be of use to somebody
https://www.instructables.com/How-to-Fix-the-33V-Pin-Issue-in-White-Label-Disks-/
After much humming/harring I went for 3 x 16TB Seagate Expansion Desktop (EXOS Enterprise drive).
I'll flog my 6TB REDs on MM when I've done copying data across and Gen8 Microserver on MM when I'm done.
<edit>
As expected drives contain ST16000NM001G-2KK103 Exos x16 Enterprise drive, SN02 firmware, I will shuck over the weekend.
Just seen this - WD 10 TB Elements Desktop External Hard Drive - USB 3.0, Black for £149.99
is this a good one for NAS (unraid)?
Just bought two of the 12Tb WD Elements drives in the sale. Both came with WD120EMFZ white label drives and both work with a Synology 918+ NAS without the pin mod. They were incredibly easy to get out of the enclosure without having to break it apart and (so far) appear nice and quiet when running. As far as I can tell, they're CMR drives, 5400rpm and air filled. For £164.99, delivered within 12 hours(!!) I'm more than happy!
(The delivery time was almost half of the time required for the NAS to run a parity check on each of the new drives - ha!)
