My news NAS is up and running, just copying data across which is gonna take a while
Had a bit of a headache with some mini SAS cable didn’t realise you need SATA (host) to SFF-8463 (target) cable, I just though it’s was all the same!
14 TB WD Elements available for £189.99 today, rumble in the Jungle![]()
Got my 14TB WD elements today - £13.5/TB. Shucked and it is White drive.
Required molex to SATA connector to power up.
It is a lot quieter than my Ironwolf which it is replacing.
Depend on your PSU. Mine is a pico psu. So I have to power it from molex. New PSU should be straight plug and play.So a straight forward SATA power connector won't work?
It will if you put a bit of kapton tape over the 3rd pin.So a straight forward SATA power connector won't work?
Raid 6 for 4 drives?
large raids using this sort of capacity disk will probably result in something failing during raid rebuild if one of the drive fails or the NAS bay is dodgy (qnap).
So that's a must on these drives? I've read that some previous WD drives needed this treatment.
Fair, I'm used to 3TB drives in a Synology so this is my first foray into larger storage drives. What would be your suggestion? I'm building a machine to consolidate NAS/server so I have 4x3.5" bays at my disposal.
