- 25 Nov 2002
- Somerset
Hi guys,
I've in my hands an Shuttle Sz68R5 with Intel i7-2600K and last bios 1.05
I added an other fan to better cooling, and push rpm in I.C.E. from bios.
This CPU works in other mainboard over 5 GHz.
I tried to overclock CPU and testing with prime95, first to 4 GHz and after 4.5 GHz, but to 4 GHz CPU starts to 40x but drops up to 3.7 GHz in maximum test, and after push to 40x.
It's a Thermal Throttling problem, in this bios I notice isn't possible change Watt power but I checked in BIOS the following option:
Power Limit 1 Value (1/8 watt), default 520
Power Limit 2 Value (1/8 watt), default 650
I increased about 960 (120W x 8) but the problem is the same.
I see this screen:
http://www.motormice.com/reviews/SZ68R5/reviewImages/image069.jpg
in this screen, there is a power technology setting, but in my bios this setting is no displayed. I downgraded to 1.04 but in this case the setting does not exist.
Congratulations on getting one
With regards the throttling... Its not temperature based, its all to do with power. I also found that the Power Limit values don't help in the Bios. If you read my comments on overclocking in the review you will see that I found a hidden bios setting which sets the maximum power the CPU can draw. Unless you change that it will keep throttling as the CPU uses more power.
Unfortunatly all my attempts to get Shuttle to allow us to change this setting in the standard Bios have been ignored so far... The only way is to modify the bios and enable this function.
