Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
It's here !!! Who else is getting one ?
Highly doubt I'll bother tbh. Its a nice lens but a very marmite focal length.
I am not sure marmite is the right word, that can apply to every lens. Not every lens is loved by everyone. But I know what you are saying, I spent the last 2 weeks in Hong Kong with just the 50mm, although i have shot some nice images, I have found the 50mm quite a challenging lens to work with. May be because I am used to the 35mm so especially at the beginning I wanted to step back a lot. It got better towards the end for sure, so I agree to a point that 50mm may not be for everyone.
There are however times I prefer the 50mm over 35, like table decor shots.
I had the same issue going the other way. I was used to shooting the 50mm so much that it took a while to get used to the 35mm. I still haven't really!
It's one of the reasons of the single lens trips, so I get to know the lens, learn about the lens, the focal length. It's good to work with all of them, if say one of them break at a job then you need to work with another focal length, you need to be at your best that you can at that too.
Not sure i could justify nearly £900 on this over the Nikon 50mm f/1.8 i have. I'm sure the Sigma is great but i'd rather spend the money on an 85 or 24-35mm prime
Looks good. Sigma must be doing well to get money out of a L lens whore!
