I doubt they'll do anything. 35Mb/s is way above the guaranteed rate.
You might be on an exchange-only line without a cabinet.
Possibly, though there are 2 BT cabinets within sprinting distance and between me and the exchange.
You're probably a reasonable distance from the cab.
I was told if my speed was below 35mb then I have the right to cancel within 3 months, gonna see if it settles down any as I've had it downloading at over 6000KB/sec
I have another question: if I change my phone line over from BT to Sky, will my phone number change?
Anyone know if there is a way to find out when sky will enable their fibre at your exchange?
Anyone know if there is a way to find out when sky will enable their fibre at your exchange? I have their llu at mine and the exchange and my cab are both enabled for fibre and have been for some time, but still no sky .
According to a few posts on sky forum this is either because BT are yet to open the exchange for others so sky can connect their equipment to the fibre network or older sky equipment that doesn't support it so needs upgrading first. Anyway to find out when they will do it?
Also, if I wanted to go to a sky line from BT now, so when it does become available I can just cancel Be* and go, how do you go about doing it? Never changed line provider before.
Thanks.
First of all you say you are with Sky LLU, meaning you have Sky Talk and Sky Broadband, then you say you have Be* ..so which is it?
I was in the same boat, exchange and cabinet enabled for fibre for 9 months, but wanted to wait for Sky's fibre but still unable to get it when it launched. I've waited til now and finally gave up trying to get more info out of Sky. I even have a friend that works for sky and he can't get any solid info either.
I've just put an order in with ADSL24 to move back to a BT-style line.
In 10 days time I'll have 80/20, sod Sky
You need to wait for Sky to carry out work at the exchange. Impossible to get an ETA. I'm still waiting.
Still can't get Fibre grrrr. My exchange has been upgraded for a while and many places where i live can get BT infinity.
The problem i think is that i live VERY close to the exchange (14-16 down 0.65 up ADSL2), they probably haven't bothered with the cabinets so close yet?
Can smoothwall pass the MER authentication through?
I'm with Be at the moment but thinking seriously about switching to Sky Fibre as Be aren't going to be offering anything better than my current ADSL2+.
I've logged into my Sky account to see whether fibre is available and it is. What I'm a bit confused about is the estimated speeds shown.
It shows Sky Broadband Unlimited as 7.0 - 14.3 Mbps. The top end of this is pretty much exactly what I sync at with Bethere, 14.3Mbps.
The Sky Fibre Unlimited is showing 40.0 - 40.0 Mbps which is a bit strange as my nearest cabinet is around 300m away following the road. Our estate was built in the mid 80s and there are no overhead cables so it may be possible that the cable runs a more direct path underground but even then it's over 100m away. Can anyone please explain how the Sky estimate is such that I will get full 40Mbps speeds and whether it's likely to be accurate?
My estimate is 40 and I'm miles from cabinet, I get about 38mb so yeah it's accurate
Call them if you want to order 80/20.
You can't be miles from the cab if you sync at 38Mb/s.
