Any idea if this works the same as the unlimited service, i.e. username/password authentication?
I use PfSense so.
PPPoE.
I use PfSense so.
Excellent, cheers
I've noticed a lot of BT types milling around various street boxes recently, and slowly but surely they've moved from one to the other and occasionally digging up the ground in a random location.....only just twigged as to what they were doing Looks like they've started at the boxes furthest away and are slowly moving in from the outter ones towards the exchange. Activation date was already moved back from the 1st of June to the 30th of June here so fingers crossed they plod on and it doesn't get moved back any further.
Just had my update emails from Sky.
Open reach engineer coming 27th April to install new master socket with Ethernet port.
Sky engineer coming 4th May to install router (he's going to have a shock when he sees my MaxTerm Intel 330D, 2GB router running pfsense) and my Draytek vigor 120 modem.
thats strange... most of the people on the trial said nothing about a sky engineer coming out ( do they have them fro broadband? )
I thought Sky just send your the router ( which you have to use as its not been cracked yet ) and BT install their modem, you then connect the two up and the Sky router does the authentication..
Okay, so it seems that they've just pushed my selected date of the 27th back to the 4th.yes i read that when it first came out... the only engineer that comes to the house is the Bt openreach engineer to install the faceplate and openreach modem.
Sky dont send anyone out to install their routers you get the router delivered in the post and plug it into the openreach modem and away you go.
Already starting to regret choosing Sky again...
I would call and check. Spoke with a few friends on the trial and only BT had to do a home visit to install the modem.
If you get the router in the post and BT still show up on the 27th to do their bit you should still be good.
Ohh and apparently Sky Fibre is using MER for authentication.
Spoof mac...profit?
go away troll pleaseOh only 30mb ha! sounds fast to me lol i can remember the 56k dial up
rumour out that sky will offer 'fibre pro' for £30 per month with 80/20
Based on the number you have provided we are unable to provide you with Sky Broadband on your current phone line. You can still benefit from inclusive UK* landline calls with Sky Talk.
