4K 60Hz vs 1440p 144hz vs 1440p Ultrawide 100hz User Experience
General Usage
Gaming
my monitor setup is as follows:
Main
1440p 144hz
Secondary
21:9
Test Setup
5930K at 4.0
16GB DDR4
GTX1080 Founders
Monitors
ASUS PG278Q 1440p 144Hz TN
ASUS PG27AQ 4K 60Hz IPS
ACER X34A 100Hz IPS
All calibrated with ColorMunki Xrite
Games Tested:
Overwatch
Witcher 3
Rocket League
WWE 2K16
Mafia II
American Truck Simulator
Euro Truck Simulator
My Reaction Time: 0.125 seconds [tested in a control environment by DVLA disability assessment centre] reason i bring this up is for the Genji test.
reason for this thread
this thread in not reviewing the Monitors Quality/Price. this is simply giving Real world user experience with side by side testing. of the various types of panels
During this testing Gsync & Fastsync will be used.
Other Notes
This Thread is my personal experiences with having all 3 monitors side by side & switching between them as daily drivers. You have the right
to not Agree with me, These are my personal experiences.
I Am bit like kaapstad in that fact that i keep & love testing Monitors, in the last 2 years ive used 10 different monitors using my own Money.
Other notes: Im a IQ Lover. This was the reason i bought these chasing the IQ race.
General Usage
Asus PG278Q [144Hz]
Their really nothing to say here As a general daily driver this monitor is Great, with no Cons except for not being IPS. Comparing TN vs IPS is night and day with black levels.
its not noticeable when solely using the TN but having IPS right next to it displaying the same content.
Asus PG27AQ 4K [60hz]
As A daily driver I dis like it. Why? 27" 4K general web browsing experience, is terrible on chrome default settings. Its readable but not nice. I have to run 150% or change font to Very Large.
I have 20/20 vision too! Widows experiences can be troublesome too DPI scaling is very hit & miss. Some applications are nice to use some look terribly blurred. Don't get me wrong you can live with or get used to it but it can be very off putting at first.
My Recommendation is to use 30" or higher screen to notice the real detail of 4K & no DPI scaling issues
Acer X34A [1440p Ultrawide]
Their really nothing to say here As a general daily driver this monitor is Great, with no Cons except being so large, 34" CAN require you to move your head side to side when browsing. evem my old
Dell 2913WM can require small move of the head. you will find that when using 29"+ displays you will use chrome/firefox not in full screen mode. The other thing to note is the stand on most ultrawides are large and intrusive
so much so using the standard on a 700mm deep desk requires head movement. this is easily fixed with a monitor arm, giving an extra 3cm in some cases, just something to note for people who do not want to head shift.
Gaming
Asus PG278Q [144Hz]
This Monitor for Gaming is Pretty Epic, The Difference from 60Hz is slaps you in the face. once you go 60hz+ you you wont want to go back, TRUST me i've Tried!.
Ive had this monitor since release & Love it. The only issue i have with this Monitor is now ive seen IPS its hard not to go i wish this was IPS.
Overwatch
with This game Fps Locked at 143FPS, its such a smooth experience. Going from 60Hz to 144Hz is pretty mind boggling.
This Monitor also allows me to pass what i call
The Genji Test.
in real world
As shown in the video Genji Rushes forward slicing through your body. why does this matter?
This monitor due to the 144hz allows me to dodge this ability as junkrat, using mine to jump him or trap him.
i have a 90% success rate dodging this ability in a real world environment. if you are competitive gamer then this of course matters to you. those few milliseconds count.
General Gaming [other games]
No issues to be concerned about, of course you need a good GPU to push Decent frames to the monitor to take the best advtanage of 144Hz
This Monitor For Visuals are Draw dropping. Imagine a TV with sharpness cranked to Max, but its real detail thats 4K @ 27"
Going from 144hz to 60Hz is instantly noticeable, however after an hour or two you get used to the difference.
what you will find is you most likely need to modify
Mouse sensitivity/DPI
Overwatch
Running this game at 60FPS on 60Hz is TERRIBLE after using 100hz+. the input lag is so noticeable i couldn't play overwatch with it. The visuals are WOO.
However, You crank up the frames to 120FPS & the input lag from the mouse just disappears. you of course wont see all the frames, but the feeling is sooo much better so much so its no problem to use.
The Genji Test
This Monitor fails what i call the the Genji Test.
in real world
This monitor due to the 60hz does not allow me to dodge this ability as junkrat, using mine to jump him or trap him.
i have a 10% success rate dodging this ability in a real world environment. if you are competitive gamer then this of course matters to you. those few milliseconds you dont have count.
Witcher 3
not much to note here, but 4K Max settings, is not going to happen unless you want 40FPS or running Titan/1080Ti Sli to get 60fps and above.
using a gamepad at 50FPS the input lag is not even noticeable. dont worry their.
Rocket League
another controller game, i dont feel the input lag using a Xbox one controller but still 100fps feels better than 60fps.
WWE 2K16
no issues
Mafia II
No issues
even this game struggles at max presets at 4K on a 1080.
This Monitor for Gaming is Pretty Epic, The Difference from 60Hz is slaps you in the face. once you go 60hz+ you you wont want to go back, TRUST me i've Tried!. However going from 144Hz to 100Hz is noticeable.
Not a big issue but you definitely notice, after a few hours it becomes normal though.
To me 21:9 is Like running Linux, When it works its Amazing!, but when it doesn't its just a pain in the ... you need to fiddle just to play a game half decently. its so bad their are programs & websites made to help you fix games
Their are also modfied exe's by modders, which can be a huge secruity concern. In my eyes i don't want to fiddle & will not fiddle just to play a game.
Some developers are better than others, but expect a decent amount of games to have issues. Even from AAA developers. especially if you play a lot of older games.
these include no Support to HUD/UI issues or cut scene issues.
Overwatch
What a terrible experience overwatch is on 21:9. you ACTUALLY lose FOV. see here > http://www.pcgamer.com/overwatchs-new-219-support-actually-reduces-field-of-view/
the real problem is you cannot fix it either.
Run 21:9 zoomed in which makes me feel dizzy
OR
You run in 16:9 mode in border less window mode having huge black bars that are size your hands
OR
You run in full widowed mode.
OR
if you run 16:9 full screen mode it stretches the image
OR
you set GPU scaling to no in Nvidia Panel
this allow you to run Full screen 16:9 with black bars + input lag
both of which increases Input Lag see below
The Genji Test using 21:9 3440x1440
in real world
This monitor due to the 100hz does allow me to dodge this ability as junkrat, using mine to jump him or trap him.
i have a 50% success rate dodging this ability in a real world environment. if you are competitive gamer then this of course matters to you. those few milliseconds you dont have count.
Overwatch is so bad on 21:9 ive moved to 16:9 monitors
Witcher 3
THis Game is Amazing & beautiful in 21:9 3440x1440 running at 100hz is very smooth experience. HOWEVER Cut scenes are broken and run in 16:9 Mode. Which can break immersion,
Their is a Modified Exe to Fix this by Modders, However im not running Modified Exe's on my PC the security risk it implicates is to large.
Rocket League
A great experience
WWE 2K16
doesnt work 16:9 only even though it says the resolution is 3440x1440
Mafia II
Works
Works, this is epic on 21:9 you can see SOO much more you can see out of each side window!
conclusion
im going to sum up my thoughts on using these as daily drivers;
their all good in their own right & nothing is wrong. However if i did this all again.
I would not buy 4K 27" again & at this time i would not buy 3440x1440 again.
21:9 is in its infancy, some may i argue its ready. Its not. its much better than a few years ago when i was rocking a 2913WM. However its not their yet.
Its as i say its like Linux, It great for most of your tasks but it doesn't just work. in a few years time when engines have native support for 21:9 then it will be the must have. but right now, the constant fiddling and hoping for 21:9 support is just not what i want to do.
the other issue is if you play a lot of older games this annoyance will come up time & time Again. (Eg Watchdogs V1) this will be reduced in time as your old games become ancient rather than old.
A few questions to help you in your choice:
Are you ultra competitive gamer?, your only choice to me is 144hz 1080/1440 Monitor
Do you not want to fiddle to get your monitor to work correctly? Don't pick 21:9
4K 60hz (27"):
I love it & i hate it
For gaming its epic, but be ready to constantly upgrade your GPU for max settings, im talking every 8 months or more!
Be aware on some games higher than 60fps may be required for you not experience input lag
be aware head shots will be harder
Be aware that at 27" Font is tiny. i would say close to usable without DPI scaling or bigger fonts in browsers.
I would say its great for casual games, no way very competitive games
WoW,ETS2,Rocket League,Casual Over watch Sure!. CS:S No...
Would i buy it again?
No, knowing what i know now even though im a IQ junkie i would wait for 4K 100Hz or more/HDR
Acer X34A
I love it & Hate it.
Gaming its amazing browsing its amazing, But the constant fiddling to get some games to run nicely (mainly older games) is just annoying.
However when it works its An EPIC experience.
be aware that you need a deep desk or monitor stand to sit far enough back
be aware your might need to move your head when gaming (bad for FPS) if your to close
I would say its great for casual games & competitive, but your mileage may vary as a few competitive games restrict 21:9.
Its the perfect Gamepad Monitor, & K+M, but more Game pad, further to sit back etc.
Would buy it again
No, & yes... knowing what i know now even though its a tough decision but i would say No. due to the fiddling required to play games & hoping for 21:9 support.
In 2-3 years i can see this being the staple Gaming monitor choice, but right now its a Lovely change
Acer PG278Q
I love it I love.
Gaming its amazing browsing its amazing, theirs no downside, except i would not but it again.
i would buy its bigger brother https://www.overclockers.co.uk/asus...descreen-led-monitor-black-red-mo-088-as.html
due to IPS support
perfect for all types of games.
Yes, but most likely https://www.overclockers.co.uk/asus...descreen-led-monitor-black-red-mo-088-as.html
Main
1440p 144hz
Secondary
21:9
