Nope, sudo covers that. You log in as a user then when you want to perform an action as the Super User you use the command for Super User DO, sudo. Get it?ms9cw said:Sorry, I'm a bit of a newbie when it comes to Linux. Do I need to login in as root? If so, how do you do that. It won't let me login as system administrator from the login screen.![]()
[font=Nimbus Roman No9 L, serif]Feisty Fawn[/font]
In the newest version of Ubuntu the developers have made enabling the repositories much simpler. Navigate to System > Administration > Software Sources. You will be asked for your account password at this point, so enter it and press Enter.
Under the Ubuntu Software tab, put a tick in the 4 check boxes. Click close. You may be told the information about the sources is out of date, simply click the “Reload” button. There you have it, all of the repositories have been enabled!
If you are using Ubuntu within VMWare you can now skip ahead to PART 2: SMP Client Installation.
SiriusB said:Get FahMon on it now so you can monitor it.
cd ~/foldingathome
./folding stop
./folding start
cd ~/foldingathome
mkdir CPU2
cd CPU1
cp fah5 mpiexec FaH ~/foldingathome/CPU2
cd ../CPU2
gedit FaH
./fah5 -configonly
cd ..
./folding stop
./uninstallService
./installService
./folding start
