My P2 is bottlenecking my GFX performance in BF3 -
benchmarks on numerous sites have shown BF3 runs just as well with 2 cores as it does with 4.
It's all about GPU when it comes to BF3.
Bulldozer doesn't really live up to its name really
Well I've got 2 and I'm getting a laggy kind of feel from the game. The framerate is about 40-50 fps but input feels laggy.
If I drop the resolution it is fine.
Monitoring CPU usage during the game shows that if I run it in Eyefinity I'm maxing the CPU across all cores. If I run on a single monitor it is no where near busy.
Edit: I can post some screens later if need.
Edit 2: Sorry should say that I run in Eyefinity - none of the benchmarks covered this
watts when talking about this CPU actually refers to "watts tha ***$, you bought a bulldozer?"hw many watts does the bulldoze use?
More likely to be buggy Xfire drivers than lack of GPU grunt with 2x6950's....
In eyefinity his frames seem decent enough.
Is it 5760x1080?
As I said, the CPU usage shoots up when using Eyefinity.
Yeah it will do, As said Benchmarks dont cover proper multi GPUs. CPU usage goes through the roof transfering data back and forth to multiple GPUs. Even 8 and 6 cores get tested. Infact its where they come into their own.
I'm probably still going to get one - the 8150.
Exactly why I am interested in the day-to-day experience of someone with a Bulldozer chip.
I stupidly jumped the gun and bought a Crosshair V thinking BD was going to be on par with a 2500k.
Please can we get back on track.
I'm interested in how it is for day to day.
My P2 is bottlenecking my GFX performance in BF3 - I can see all 4 cores maxed. I guess it's the CrossFireX + the extreme resolution.
Strange that. I've never had any slow-down or fps problems on my i7 920, & I thought that the 2400 was meant to be a stronger chip. I was also under the impression that BF3 was far more GPU limited than CPU.
I cite the following paragraph from bit-tech's BF3 performance analysis.
"It didn't matter whether the CPU was running at 3.2GHz, 3GHz or even 2GHz; our benchmarks returned the same results. Even when we dropped the CPU down from four cores to only two, the in-game frame rates proved annoyingly stubborn. While BF3 will load itself across all four CPU cores when presented with a quad-core CPU, it seems to have little benefit when it comes to performance, running just as well with much lower clock speeds, or on a dual-core CPU."
Not that I'd waste my time reading bit-tech reviews, but did they say how they tested this? Online anything uses a ton of CPU. I mean, play counter-strike with no one in a server and you could probably get 1000fps, but play it in a 64 man and you'll get 150fps. Just testing a game in single player means absolutely nothing if you plan to play online.
Source: http://www.bit-tech.net/hardware/2011/11/10/battlefield-3-technical-analysis/7
I don't doubt that you've experienced some kind of improvement, it just surprises me a little. Like I almost fell off my chair in surprise, although I managed not to make a squealing noise at the same time. That would have been embarrassing, especially at work.
