Strange that. I've never had any slow-down or fps problems on my i7 920, & I thought that the 2400 was meant to be a stronger chip. I was also under the impression that BF3 was far more GPU limited than CPU.
I cite the following paragraph from bit-tech's BF3 performance analysis.
"It didn't matter whether the CPU was running at 3.2GHz, 3GHz or even 2GHz; our benchmarks returned the same results. Even when we dropped the CPU down from four cores to only two, the in-game frame rates proved annoyingly stubborn. While BF3 will load itself across all four CPU cores when presented with a quad-core CPU, it seems to have little benefit when it comes to performance, running just as well with much lower clock speeds, or on a dual-core CPU."
Source: http://www.bit-tech.net/hardware/2011/11/10/battlefield-3-technical-analysis/7
I don't doubt that you've experienced some kind of improvement, it just surprises me a little. Like I almost fell off my chair in surprise, although I managed not to make a squealing noise at the same time. That would have been embarrassing, especially at work.
Not that I'd waste my time reading bit-tech reviews, but did they say how they tested this? Online anything uses a ton of CPU. I mean, play counter-strike with no one in a server and you could probably get 1000fps, but play it in a 64 man and you'll get 150fps. Just testing a game in single player means absolutely nothing if you plan to play online.
