Sorry folks,
Cant find a comparison anywhere.
Does the 4850 indeed offer a performance increase over the current similarly priced Nvidea stuff?
Um, the reviews I've seen suggest they perform pretty much the same as each other with the 9800GTX+ edging ahead a bit.
My advice? Get the 9800GTX+ if it launches at same price over here.
Sorry folks,
i'm deducing (from reviews/benchies) that one of these isn't a worthwhile upgrade from an 8800GTX.
Worthwhile though from an 8800gts 640mb?
I might go ahead if you guys reckon so![]()
Well you can't go wrong for half the price I bought my GTS for then can youThanks!
im running a 8800gts 320.. waiting on the 4870's tho, have a feeling it will be nearly time to trade in the old trusty 4400x2 as well
