Installed mine last night and it doesn't help much with mine, only 20mhz on the core even though the temps only get to 45 max although i wasn't expecting it to really.
Good to know. Are you running two 680's (noticed you had the same screen as me).
What core OC you running with now khemist? If I blow really hard on mine, I can just about reach 185. Not sustainable though for general performance. Although the fan isn't the loudest at 85% it still perforates my ear drums![]()
If anyone is interested in my PCI-E 2.0 versus 3.0 comparison, take a look here:
http://forums.overclockers.co.uk/showthread.php?t=18378379&page=5
You won't be disappointed.
You see, that's what people would forget. Even tho 480's are hot and use more power, You never needed to put the heating on when using your system.
So you broke even with the power used by the 480, on your heating bill.![]()
I got one of the "OCUK" Palit cards but im a little concerned its running to hot. 62c idle and like 80c running BF3 my case is pretty well cooled and managed by 2x 5870's fine. Anyone else been experiencing high temps?
That does seem pretty high. Just check that the fan speed is set to Auto, as it shouldn't be getting up to 80C.I got one of the "OCUK" Palit cards but im a little concerned its running to hot. 62c idle and like 80c running BF3 my case is pretty well cooled and managed by 2x 5870's fine. Anyone else been experiencing high temps?
Where would I go about checking for that please?
