Solar panel production figures
Quite a nice day today, well above forecast for once - 26 expected and 33.5kWh generated so far… exported 8 because I had to go to work so couldn’t soak anymore into the car.
I set up home assistant to the flux rates just to get an idea and it would have been £1.92 of export today without even trying to dump any during peak (and having shoved about 10 into the car this morning). Should be pretty interesting for the summer.
41.7kWh generated, 12 to the grid and consumed 19, battery currently at 96%.
15kWh forecast for tomorrow, though given the weather forecast I'm not sure on that, but I'm going to take a chance and not charge the battery.
Starting Tuesday morning, I will charge the battery and hold until 16:00, then force discharge down to 20% SOC
Still generating 100w but cracked 30 again. Just waiting on my flux export to kick in to make the most of the 4 to 7 discharge. Training the wife how to use it will be the hardest bit.
Spent most the morning averaging around 700w, it finally started to brighten up around 13:30, battery is currently at 44% so I think we'll have a enough to see us through the peak period espeicially if it stays bright, we've got leftovers so the ovens not required today.
14.55kWh in the end, somehow exported 1kWh, and imported 1.5kWh when I accidently turned on charging - I set up my scheduled charge to 100% for tomorrow between 2am and 16:00, but was within that time period today, so it started charging.
Almost up to third in the efficiency ranking. 16.3 today, but like ronski exported 4kwh as the sun came out all in the middle of the day.
