Solar panel production figures
I'm ticking over and up to around 600 but west facing so this is normal
Blue clear skies, weather forecast for this afternoon is sun/showers
Probably a rinse repeat of yesterday as that was exactly the same, but if so thats good enough for me. I ideally need around 10kwh of generation to be zero peak from grid
I'm still charging to 100% battery overnight since at 7.5p a unit its no drama if I send some to hot water diverter which saves me around 6p per unit of gas.
Still not sure on my export with Octopus, getting odd things on my dashboard. Others on Octopus SEG is it on your bill monthly or different?
they put it on my monthly bill....11th of every month for me. So today they have paid me out around £38 for the last 31 days
thanks. Just trying to work out if its all fine
Technically my first day as the last day of my last bill but it wasnt on there and they had to force my bill through
I am seeing some data and the errors reduced today so I guess its probably ok. Will just have to wait it out until early May when I get my next bill.
It wont be much anyway
https://imgur.com/a/j5RUSqX
Still struggling to post pictures from phone, apologies
This the front of my inverter but I'm not sure how to read it
Does anyone have any suggestions for getting instructions on how to use?
You can just link the image directly here btw.
Right click the image and open in a new tab, then copy that url into the insert image thing.
To resize it if it's huge, add an h just before the .jpeg. https://i.imgur.com/pjqRNGwh.jpeg
Up to 12kWh generated so far, it's much brighter than expected and rain holding off for now which is good as the sheets are out!
And just spotted this! Think thats the highest i've ever seen it go!
less than 100 here.....
The darkness was short, have been regularly seeing 7kW, highest peak today is 8697kW. 18.5kWh so far
Do the actually pay you each time, or just credit the account?
We got a pleasant start, so again the East array helped loads. Just finished a spell of rain but likely better than the forecast gave. Will update once the generation stops.
