Solar panel production figures
Not when its falling but snow reflects a lot of solar radiation so chances are if you get some clear skies after the snow and it stays nice and cold you could get some very tasty numbers.
You may need to get a long broom to push the snow off your panels however :p
it didnt last long and the sun is sort of trying to come out.....we getting around 400watts through the panels
Looks like today could be a reasonable day as we're getting sunny spells. Yesterday was pretty good with 13.5kW, sending us over 200kW for the month.
It just hit an output of 5.09kW which in theory shouldn't be possible as we only have a 4.8kW array. I guess that's as good as it'll get.
Now we've got an extra battery bank (12.25kW total now) it can charge them quicker too. It was filling up at a rate of 4.1kWh just now. We've gone from 27% to 74% in quite a short period of time.
The energy savings are surpassing my expectations so far. We average about 13kWh a day usage and that has dropped to just 3.3kWh from the grid this month. We have air con so I'm expecting even better in the summer as we average about 17kWh per day then.
New grid consumption low of 2.6kwhs yesterday ( zero battery use, as i dont have one ).....should get even lower as we go forward to spring summer as days will get longer
Wow just hit a new peak 6278w output… amazing that just one month ago the peaks were more like 4800w.
It’s one of those afternoons now where the clouds are moving through so I’m probably getting the cooling panels, burst of sunshine high peak thing going on, but given the inverter is 6kw I can’t complain about seeing 6.3kw!
That's fantastic. I peaked at just over 6kW today.
But it's really cloudy now.
Today had the makings of a great day but clouded over in the afternoon. Should end up around the 13kwh mark. Still battery up to it's highest point so far this year at 45%
