- 19 Oct 2010
If your battery covers all of your needs then you'll never draw from the grid during the day. If your battery isn't big enough then this is where solar can help to "top it up"
When you calculate your ROI, are you only counting the amount less the electricity is costing you in the night? Or are you also taking account of how much more it is costing you during the day?
My calcs were done assuming a system big enough to cover my full daytime usage
my only worry was if the off peak rate ever was discontinued it would render my investment relatively useless
I originally was looking at the same route, 2 Tesla powerwall 2's - my only worry was if the off peak rate ever was discontinued it would render my investment relatively useless, so now looking at both solar and battery
Economy 7 has been around since the late 70's so it's unlikely to disappear but obviously there's no guarantee.
Running batteries with solar makes the most sense, I've already got a 4.2kWh install but no batteries, my setup is already generating enough day to day to fill 10-12kWh of storage which would more than cover a days use.
I don't have a day and night rate on my billing currently. And it's just occurred to me that I don't even have a meter with two displays.
Does that mean if I ever wanted to use a tariff with cheaper night time rates, I'd have to pay for a new meter install first?
I'm on the south coast, my roofs set back a bit from the other houses, so misses on the early sun.
2018 - 4069
2019 - 3924
2020 - 4022
2021 - 3266! Ouch
Can anyone recommend glow green? 2 local companies have quoted me but for 12 ja 360 panels and solar edge 10kwh battery is around 16-19k.
glow green is 13 jinko tiger and 5.2kwh givnergy battery and inverter for about 10k which is a massive difference. But their review recently on trust pilot are a warning flag
Anyone got any recommendations on solar installers in Cambridgeshire/Peterborough/Huntington area?
Absolute rip off. Go elsewhereJust had a quote for a 3kw system plus 5.2kw battery, inverter and night charging for £10.5k
Key questions are will 3kw fully charge the battery. Will battery have enough power to cover all electrical items in the evening/minimal pull from grid. Is it more cost effective to have dishwasher/washer running during economy rate between 12pm and 5am or during peak sun? Is it a realistic pay back period? Who are the good companies to go to for a quote?
My ASHP installer recommended https://www.redmileenergy.co.uk/ when I mentioned I was thinking about PV installs last week
Don't forget that bifacial panels are better than the normal panels these companies fit here in the UK.
And making your own 24/48 V Lifepo4 pack is very easy.
