Do the figures look reasonable? Too high maybe?
I'd say the 6kW system is the most accurate based on a 5kW inverter that 6kW of panels will for some part of the day cause a bit clipping in peak summer months. As SE facing but with a good 45 degree angle on the roof pitch, then you'll also benefit from the early light in the lower sun months as well, but as always you can only give a rough estimate as some winters can be very sunny and cold and others very cloudy and wet, averaging 7kWh per day in December would be a good figure if achievable. You might find that the averages for the summer are higher and the ones for winter are lower but overall, 6.8k MWh is achievable.
