There are a few good UK Solar Facebook groupsAre there any good dedicated, preferably UK Solar forums?
4kw solar into a 3kw inverter (installed in 2012). It's a Tesla battery. You tell it when your cheap electric period is and it decides if it will charge up or not. It learns usage patterns and reads the weather forcast. I had it installed in November and after the 1st week I don't think it's algorithm has ever left me short. This weekend for example it didn't charge at all over night. Yesterday I spent 20p on electric.![]()
I honestly really love the look of the Powerwall, as well as the aesthetics of the app. I know that's a touch shallow but I find it makes the experience just that much better. Seems like there's a reasonably high premium on a Powerwall though compared to similarly sized systems from other manufacturers.
I'm thinking I'd like to do the transition in stages. First would be a battery install (making sure it's solar-ready) and then the solar PV install.
If I were to put the batteries and other gear in the loft to keep it tidy, would having a long cable run to the consumer unit and EVSE cause much in the way of losses? As I mentioned on a previous post, the incoming electric cabinet and consumer unit are at the front of the house on the same wall, consumer unit inside of course.
@john_smith @Journey Are you both on Octopus Go? I had a quick look at their website and it looks like they don't allow export (SEG) in tandem with Octopus Go. Are you just charging cars and battery at the cheap times (and letting solar trickle charge/power home during the day)?
Sorry. I actually mixed up a couple of things, but yea looks like you have some kind of anomaly combinationThey must have only recently changed that as I am on Outgoing Octopus with 7.5p SEG rates, and Octopus Go Faster 5 hour at 5.5p/15p. I was actually on Agile and Go for a while but they fixed that, damn it!![]()
Our SEG tariff is perfect for people who’d like to join Octopus for their energy export, but stay with a different supplier for their import tariff (i.e., the power your home uses from the grid). It’s also a great option for people who want to use Octopus Go for their import tariff, and are also keen to keep getting paid for their exports at the same time.
Currently, you can't be on both outgoingOctopus and OctopusGo, our EV tariff, at the same time.
Sorry. I actually mixed up a couple of things:
* You can use their normal SEG tariff with GO:
Some grown ups have a family at home during the day. Ask your Mummy and Daddy to explain it to you one day.
So i've just looked up the system that came with my place, sounds like it's quite weak compared to what others are putting in?
- Type: PV
- Number of panels: 8
- kW per panel: 0.26
- Total kW: 2.0
Yes, 4kW is the standard as you can install it without permission from the network operator. 2kW is small but better than nothing
Fair enough. Depending on the types of panels I guess I could swap out a few to try to jump this a bit
