I dont have a hub and could see it..
Someone tippex'd over your harvi brah
Good shout. Well done
Out of interest have you connected it to your WiFi network at home?
It has no hub just the ct to measure export so it turns on. If I had facility to use the app I would try it out. I can order another coil and put it in myself but I think you need the havi/car hub to visibly monitor?
That's the serial for me? I need the reg code too!
are you sure your eddi has built in wifi/ethernet? How may antenna does it have sticking out of the top and where are they placed. I might be wrong but if it's 1 and its in the middle is the old one without built in ethernet/wifi, if there are 2 then it's the new model.That's the serial for me? I need the reg code too!
Nope!Could I please ask a question on inverters.
If the panels are lets say 7KW, does it matter how large the inverter is?
I am told that even with 7KW panels diverting full power to an EV charger, a G98 3.6 inverter is fully capable of handling this energy and diverting it as needed.
Is this true?
That's what I thought but when I questioned this I was laughed at!Nope!
A 3.6 inverter is unsurprisingly able to handle 3.6kw, so energy above this will be 'clipped' - ie lost...
Yes, this is possible, I could fit another 3 panels in my garage roof but then again even 16 panels are not to bad. Many thanks!You'll have to be careful going too near the edges of the roof, my installer wanted minimum of 30cm clear on the edges, and ideally 40-50cm. You may need to lose the left most vertical panel to gain a little more edge distance on the right.
They fit them onto rail kits that go into the rafters, so you'll also need to bear that in mind, it's most likely easier to install panels next to eachother on the same axis, though there seems to be no issue installing them with say a row that are vertical, and a row beneath that are horizontal.
Also your roof and chimney stack could at times shade your own panels, you may find some clever use of optimisers where you get the most shading potential is worth it.
Yeah, on a clear, sunny day with 7kw of panels, you'll easily be hitting 5-7kw, so that's a lot of waste to HungryHippos pointThat's what I thought but when I questioned this I was laughed at!
