Would you be able to swap back if you needed to?
Think its 28 days between any tariff changes with Octopus, IE if you change 28 days wait before you can change again.
and I went with Octopus as I plan on moving over to them come April for the Agile tarriff, although i'll no doubt need a new meter as mine is a dumb smart meter currently.You can indeed shop about, but I just stick with Octopus and hope one day they improve the rates.
I don't want the headaches of another supplier, and by all accounts, some of them are incredibly slow at accepting SEG applications.
Was that when octopus took over? I'm currently with sainsburys which I suspect could be the issue as it isn't in their interest to sort it out with a fixed flat rate.
My Smart, dumb smart , smart, dumb smart meter still hasn't been sorted, must be sixteen weeks since I got Octopus on the caseIt's an oxymoronic meter!
Mine was a dumb smart one, but then it became a smart smart one, luckily!
seems to be mixed result with octopus, they fitted my new gas and electric smarts 48hrs after a phoned and asked for new onesMy Smart, dumb smart , smart, dumb smart meter still hasn't been sorted, must be sixteen weeks since I got Octopus on the case![]()
I still have a SMETS1 meter, I'd like to have an Eco 7 SMETS2 fitted but apparently there's no appetite to do it these days.
Ah well, my export meter and normal meter are sending the 30 minute readings, but for some reason things aren't synchronised all the time as I go onto my account and it can't always tell me my usage. Meh, as long as I'm being charged correctly that's all I care about at the moment.
Very tempted to switch over to the tracker tariff having looked at it, with solar and batteries it could be quite impactful.
I believe as your SMETS1 meter is giving 1/2 hourly readings you don’t need a new SMETS2 meter, why the need for a change?
We opted to have a smart meter installed in 2014 when first offered. It was free, so why not? The smart element died in less than 2 years and meter readings went back to normal. 18 months ago when we had a load of changes, I looked at getting a new one. Yes I could have one but would have to pay. "How much?" I asked. £300-£400. How long until it will be replaced anyway was the next question. Not until it is 10 years old came the answer. From memory the old meters with dials were good for 25 years. Smart meters, smart motorways, and smart phones. The only smart thing about them all are the people who persuaded us all to get them.Wasn't sure really - just thought SMETS1 was old tech now.Not really looked into it.
did you fit it yourself and were did you fit it too??I fitted my Solis AC Coupled Inverter and 5kw Pylontech battery at the weekend. Got a few issues with the Solis Cloud app, but otherwise it's all working perfectly.
