- 25 Mar 2004
- Fareham
So I have the worst of both, flat which would be good for south (but I suppose they could be tilted, but would look awful from a distance.)
And then East/west I have a garage roof pitched.
Assume I could get an install for 10k, it would definitely take years. We use about £2800 a year elec on current projection. Assume I had an install even generating half that (over 3500kwh per year, not sure if doable), it's going to take 7 years to pay back by my very quick man maths.
You could install the ones on south as flat for aesthetics but it will do less generation for sure. Not like it would be 0 though.
MKW sent me this earlier.
Flat tilt of basically 0 degrees on S facing is about 84% as good as 30-40 degrees. If you can add a slight tilt it will help a bit.
My roof is 45 degrees so I have S facing doing probably near to 100 % and W facing at more like 75%.
