- 4 Aug 2007
- Wilds of suffolk
Thats whats confusing me, because on the website of said inverter its says 50v start up...i'm thinking they have put the wrong information for the inverter, as it states in the blurp one MPPT, but as you can see in the specs it has two.
This is what the website says for my inverter
The Growatt MIC 3600-X is a light and compact residential inverter. The maximum DC voltage is 500V, a start voltage of 50V. There is one MPPT with a maximum input of 13A and features a DC switch, surge protection, and an option for AFCI.
Cheers
I got the inverter specs on my desk up in my office…its defo dual mppt. So will check in the morning when i go back into work.Are you quoting that from LR Renewables website? As that's the only place I can find mention of a MIC 3600-X, on that website they advertise it as a dual tracker, yet in the write up underneath they state it only has one tracker, it appears they don't know what they are talking about, you need to check the manufactures specification. There isn't an MIC 3600-X on the ENA register either.
What's the model number on your inverter?
PS. I posted this in this thread, which is more appropriate.
Ah ok, will sort it in a bit.@Nathan you need to edit your picture link, just use the picture button and enter the URL.
What panels are those, they look pretty big, also whats the plastic underneath the frames, looks like plastic bags?
I actually managed to find some proper sealing plugs for when I put some of my panels up, did think about bags, but knowing my luck they'd get damp inside as I didn't know exactly when the rest would be done.Plastic is some bags I taped on the end of the connectors.
Still doesn't say anywhere that it would provide power over your internal wiring like a AC coupled inverter.maybe this link shows the solution better - you can see in the pictures that the generator is plug into the mains
EcoFlow PowerStream Microinverter
EcoFlow BKW-Battery Cable (sold separately) is needed for connection with an EcoFlow Portable Power Station. Recommended to use with EcoFlow Smart Plugs (sold separately). 0% of energy waste Power for day and night Smart Control & Monitoring: Smart Plugs & EcoFlow App Quick & Easy Registrationuk.ecoflow.com
Theres a panel on the wall to the right of the ecoflow system, thats wired directly into the socketStill doesn't say anywhere that it would provide power over your internal wiring like a AC coupled inverter.
I don't see how it would be able to do that without being able to measure import/export to the grid. Can't do that from just a 3 pin plug.
Other products I've seen from EcoFlow that advertise that function show an additional AC coupling that you can wire in to your home that allows that function.
Got a proper picture of the first install on Saturday! PRetty funky!Funny how once you get Panels installed you notice more and more the installations of various houses. was out on my bike at the weekend and spotted this ground mounted array which appeared to be on a movable jig, it was fairly sizeable being above the hedgeline, but looking at maps it looks like it moves, it was 4 or 6 panels in size.
Google Maps
Find local businesses, view maps and get driving directions in Google Maps.www.google.com
also saw this in majorca on the north side of the island where the hills/mountain top must block a fair amount of the light during the day over the main house, but they'd managed to put them right at the bottom of their land overhanging a wall.
New item by Paul Morris
photos.app.goo.gl
Both have given me some food for thought about looking at mounting vertical panels on my tilehung house on the south side with optimisers which would in theory provide real benefit over the winter from my shaded strings with no optimisers and probably not cost a significant amount more than retrofitting. I think I could get potentially 8 panels on in total, will speak to my installer to see what is possible.
indeed, plus the right angle throughout the year too could make a massive amount extra in the winter months.4 panels always facing the ideal direction - should make a big difference. IMO, increasing power early and late in the day is much more important that peak power a noon. It's what I've been making changes to improve for this year.
Looks to me like something someone in the trade, or a competent DIYer would do.I just meant from the perspective of those systems I have seen are not cheap, even remotely. I would highly doubt the payback vs additional costs on just spending that on maxing panels on that space they are using.
A sun tracking system I would estimate would probably be 30-50% more generation than a south only when the sun is high.
In winter much less since in winter the sun comes up in the SE and sets in the SW, its actually the opposite to what you expect vs static panels, looking at their setup I assume the majority are south facing already as it wouldn't have made sense to put them where they did otherwise.
The time of generation vs amount is a balance, if you have enough storage to basically get you past your troughs then time of generation is irrelevant (bar Flux now that is a thing). Maxing production more important especially in times of low yield (ie winter)
Eg a south array with decent amounts of battery is always going to beat facing those panels east or west.
Without battery however having as wide a generation window as possible will of course be more optimal.
I can't imagine that many people are getting solar without batteries now. Adding batteries doesn't push the ROI out far and adds a load of flexibilty in, plus you can add whole house backup etc.
I expect TOU tariffs will become more of a thing as we go greener and having batteries will add a lot of additional cost prevention to peoples domestic bill by being able to negate the worst.
