- 2 Dec 2022
- south east hampshire
I forgot to mention how thermally efficient our project should be. A 3 bed semi now has an L shaped single storey extension. The back and the side are super insulated. One wall is in common with the neighbour which only leaves the front which is the narrowest wall. The extension is about 145% of the size of the original groundfloor footprint. We are at first fix, but going on what someone else has achieved with a similar project, his heating bills have actuallly come down!!!!!!!Completetly agree about insulation. Our building regs were only tighened up last June. All applications which had paid for their building regs fees proir to last June's date are only having to comply with the old regs which were appallingly lax. I am just finishing a project where we have fitted full fill PIR insulation in all walls. These are interlocking "lego" type panels. They come in thicknesses of 90mm, 115mm and 140mm. All are designed to have a 10 mm gap in the wall and are made by all of the big boys under different brands. A warm roof is much more thermally efficient and I recommend those. Scandinavia is the place to look for the way forward.
Glazing is an interesting one. We live in a south facing house, and prior to fitting panels, we absolutely knew that the sun gave us free heat. Panels work at around 20%. With the sun shining we get about 1kw per square metre of glass. Most of that warms up our house. Building regs take the passive U values and are seen as a minus. When orientated correctly they really help. (U values are a measure of thermal efficiency and building regs just look at how much a window will leak heat).
For nearly 30 years I have tried to get people intersted in making sure that new properties have south facing windows and that orientation is included in EPC's as this reflects the real world.
Improving U values in older properties is very expensive as the only sensible option is to to insulate the outside of the building which often conflicts with the roof
