You won't. Modern pabels have bypass diodes to prevent one bit of shade crippling the whole string.I just didnt want to cripple whole row of panels during summer for SEG for octopus to get as much money as possible back after filling batteries.
Was more to show progression of sun as one panel getting hit takes them all out depending on inverter.Irrelevant at that angle. The panels will only be generating a dribble of energy at this point anyway.
Been up there over 30 years so far with all the weather and wind we have had, tbh its disconnected and could be taken down but nobody has ever gone up there lolI'd be more worried of how much damage that old aerial would do to my panels one winters stormy night.
I think ours is connected with next doors so its not all ours.I got the builder to take down our chimney to stop any pesky shadows spoiling our generation
Not sure where you're doing your homework, but it seems like you've got quite a lot of bad information.Was more to show progression of sun as one panel getting hit takes them all out depending on inverter.
I have G99 approval I think however my inverter is only set to G98.
not sure it is worth me bothering to change..... the reality is my generation rarely if ever hits 4kw anyway and if it does it's for a few mins and with my home back ground use.being 200-300w and that is if I am not doing anything am not sure it'd worth the agro
I knew about these but not sure if either come as standard ill have to discuss it with the chap coming next week.Not sure where you're doing your homework, but it seems like you've got quite a lot of bad information.
A shaded panel wont take out a string anymore. Modern pabels don't have that problem. Watch this video for why.
Solar Panel Shading (Part 1): Are Optimisers and Micro inverters Worth It?
Optimisers and micro inverters are said to improve your solar output in the event of shading. In this video, we look closely at those claims and if they're w...youtu.be
Exporting more than 3.6kw has nothing to do with single phase. It's the cutoff point where the power network has to approve the connection as opposed to just being informed. A 3.6 inverter can be installed then a G98 form sent to the DNO after installation. Over 3.6kw a G99 form has to be sent off and approval granted before it can be connected to the grid.
Although inverters can often be configured to run at 3.6kw to meet G98 requirements - so the installer could install the system, set it to run at 3.6kw then reconfigure to its full capacity once the G99 is approved.
Been looking at Canadian Solar 395w panels that was originally put in my quote and cant see anything to indicate if they come with optimizer fitted, I know it won't be micro inverters at £144 a panel.
Generally panels don't come with optimisers or micro inverters, they are added afterwards if required. You don't need either given the little shading you get, they are just another thing to go wrong, and being on the roof difficult to access when they do.Been looking at Canadian Solar 395w panels that was originally put in my quote and cant see anything to indicate if they come with optimizer fitted, I know it won't be micro inverters at £144 a panel.
